メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto E Battery Replacement
必要な工具と部品
  1. Motorola Moto E  Battery Replacement, Battery: 手順 1、 2の画像 1 Motorola Moto E  Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn off the device before beginning the battery replacement.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola Moto E  Battery Replacement: 手順 2、 1の画像 1
    • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola Moto E  Battery Replacement: 手順 3、 1の画像 1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
    FixBotに聞いてみる
    コメントを追加
  4. Motorola Moto E  Battery Replacement: 手順 4、 1の画像 1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
    FixBotに聞いてみる
    コメントを追加
  5. Motorola Moto E  Battery Replacement: 手順 5、 1の画像 1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Motorola Moto E  Battery Replacement: 手順 6、 1の画像 1
    • Lift gently on the battery using the metal spudger tool.
    • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
36 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Alex Craig
メンバー登録日: 03/11/15
2,611 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G7
2 メンバー
20のガイドは作成済み
7件のガイドコメント
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - 返信 共有
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - 返信 共有
This worked very well for me, many thanks!
Tony Franks - 返信 共有
which battery type or brand should we purchase????????
hridaya123.praja - 返信 共有
Excellent, clear instructions!
Gerald Griffin - 返信 共有
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 24
過去 30 日: 119
今までの合計 79,439
