メインコンテンツにスキップ
Motorola Edge (2022) Back Cover Replacement
必要な工具と部品
  1. Motorola Edge (2022) Back Cover Replacement, Heat the right edge: 手順 1、 1の画像 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: 手順 2、 3の画像 1 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: 手順 2、 3の画像 2 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: 手順 2、 3の画像 3
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: 手順 3、 2の画像 1 Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: 手順 3、 2の画像 2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  4. Motorola Edge (2022) Back Cover Replacement, Heat the bottom edge: 手順 4、 1の画像 1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  5. Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: 手順 5、 2の画像 1 Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: 手順 5、 2の画像 2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  6. Motorola Edge (2022) Back Cover Replacement: 手順 6、 2の画像 1 Motorola Edge (2022) Back Cover Replacement: 手順 6、 2の画像 2
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  7. Motorola Edge (2022) Back Cover Replacement: 手順 7、 1の画像 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  8. Motorola Edge (2022) Back Cover Replacement: 手順 8、 2の画像 1 Motorola Edge (2022) Back Cover Replacement: 手順 8、 2の画像 2
    • Rotate the pick around the bottom left corner to slice the adhesive.
  9. Motorola Edge (2022) Back Cover Replacement: 手順 9、 2の画像 1 Motorola Edge (2022) Back Cover Replacement: 手順 9、 2の画像 2
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  10. Motorola Edge (2022) Back Cover Replacement: 手順 10、 1の画像 1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  11. Motorola Edge (2022) Back Cover Replacement: 手順 11、 2の画像 1 Motorola Edge (2022) Back Cover Replacement: 手順 11、 2の画像 2
    • Rotate the pick around the top left corner to slice the adhesive.
  12. Motorola Edge (2022) Back Cover Replacement: 手順 12、 2の画像 1 Motorola Edge (2022) Back Cover Replacement: 手順 12、 2の画像 2
    • Slide the pick along the top edge to slice the adhesive.
  13. Motorola Edge (2022) Back Cover Replacement, Remove the back cover: 手順 13、 2の画像 1 Motorola Edge (2022) Back Cover Replacement, Remove the back cover: 手順 13、 2の画像 2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
終わりに
To reassemble your device, follow the instructions in reverse order.
作成者
4人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
61,613 ポイント
445のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,086のガイドは作成済み
コメント 1 件
Where can I find the rear cover to replace it with? Mine is spiderwebbed.
bigrebone - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 63
今までの合計 1,445
