メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Droid 4 Battery Replacement
必要な工具と部品
  1. Motorola Droid 4 Battery Replacement, Removing Rear Panel: 手順 1、 3の画像 1 Motorola Droid 4 Battery Replacement, Removing Rear Panel: 手順 1、 3の画像 2 Motorola Droid 4 Battery Replacement, Removing Rear Panel: 手順 1、 3の画像 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola Droid 4 Battery Replacement, Battery: 手順 2、 1の画像 1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola Droid 4 Battery Replacement: 手順 3、 2の画像 1 Motorola Droid 4 Battery Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
25 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Gaetan
メンバー登録日: 12/26/12
9,613 ポイント
18のガイドは作成済み
17件のガイドコメント
Jerk at the verizon store said this wasnt possible and tried to sell me a new phone, dumbass. Thanks for the guide!!
Rose M - 返信 共有
Worked great ! Ordered battery fro Amazon and with Torx kit...5 minute job !
Peter Kendrick - 返信 共有
Peter- I ordered a replacement and was able to change the battery. However, once in place, the phone would not boot up and would only show the battery icon with a question mark in it. Did you run in to this problem?
Ed Barton - 返信 共有
The battery in my phone started swelling so I ordered a battery from Amazon. Changing the battery was easy, but now the battery icon has a red question mark in it. How do I reset the battery icon?
Tracy - 返信 共有
Tracy -
I had the same problem.... Will be buying a new battery, torx screwdriver, and spludger tool and replacing the battery soon. Then I can use the phone as a backup device, or a second phone (new service needed for new line), in case my new Moto X dies....
Chris
Chris - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 84
今までの合計 40,743
