メインコンテンツにスキップ
Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement
必要な工具と部品
  1. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 手順 1、 3の画像 1 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 手順 1、 3の画像 2 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 手順 1、 3の画像 3
    • Remove the battery pack cover.
    • If there are any batteries inside of it, remove them.
  2. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 2、 3の画像 1 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 2、 3の画像 2 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 2、 3の画像 3
    • Place an iFixit opening tool between the seam of both the front and side plates.
    • Move the tool repeatedly along the seam between the two plates until the side plate is wholly disconnected from the front plate.
    I find it easier to go from the back by the side of the battery compartment. That seems to work better with the positioning of the clips for removing the cover.
    MaFt Morley - 返信
    I agree with MaFt; the side approach seems to give a lot more resistance than the back approach. I also recommend going at it from the side of the battery compartment.
    Edward Rocca - 返信
  3. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 3、 3の画像 1 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 3、 3の画像 2 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 3、 3の画像 3
    • Remove or pick a hole on the warranty sticker label to reveal the center screw.
    • Remove all five screws from the backplate using a TR8 Torx screwdriver.
  4. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 4、 3の画像 1 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 4、 3の画像 2 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 4、 3の画像 3
    • Remove the front plate from the controller.
  5. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 5、 3の画像 1 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 5、 3の画像 2 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 手順 5、 3の画像 3
    • Pop-out the old thumbsticks and connect the new thumbsticks to the joystick.
終わりに
16 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Edgar Galindo
メンバー登録日: 03/20/22
509 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 8-80, Briggs Spring 2022 CSU Los Angeles, Team 8-80, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S8G80
1 メンバー
4のガイドは作成済み
4 件のコメント
Does this method fix joystick drift?
Aaron - 返信
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Kris Rodriguez -
Where is the article addressing stick-drift/replacement, if this is not it?
Pictory - 返信
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 101
過去 30 日: 404
今までの合計 26,834
