メインコンテンツにスキップ
Microsoft Surface Laptop 3 15" Headphone Jack Replacement
必要な工具と部品
  1. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Prepare your device: 手順 1、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Prepare your device: 手順 1、 2の画像 2
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
  2. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Flip the laptop over: 手順 2、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Flip the laptop over: 手順 2、 2の画像 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  3. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Removal tip: 手順 3、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Removal tip: 手順 3、 2の画像 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  4. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the rear feet: 手順 4、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the rear feet: 手順 4、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the rear feet: 手順 4、 3の画像 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  5. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the front feet: 手順 5、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the front feet: 手順 5、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the front feet: 手順 5、 3の画像 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  6. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 6、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 6、 2の画像 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  7. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 7、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 7、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 7、 3の画像 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  8. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the upper case screws: 手順 8、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  9. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Open the display: 手順 9、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Open the display: 手順 9、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Open the display: 手順 9、 3の画像 3
    • Flip the device over.
    • Open the display as far as it will go.
  10. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Lift up the upper case: 手順 10、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Lift up the upper case: 手順 10、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Lift up the upper case: 手順 10、 3の画像 3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  11. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the ribbon cable: 手順 11、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the ribbon cable: 手順 11、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the ribbon cable: 手順 11、 3の画像 3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  12. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the upper case: 手順 12、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the upper case: 手順 12、 2の画像 2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  13. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the SSD screw: 手順 13、 1の画像 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  14. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the SSD: 手順 14、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the SSD: 手順 14、 2の画像 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  15. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the tape: 手順 15、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the tape: 手順 15、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the tape: 手順 15、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • During reassembly, if the tape is sticky enough to be reused, reapply it.
  16. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink shield: 手順 16、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink shield: 手順 16、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink shield: 手順 16、 3の画像 3
    • Use an opening tool to pry up the front edge of the metal shield covering the heatsink.
    • Try not to deform the shield too much—you'll need to reinstall it during reassembly.
  17. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 17、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 17、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 17、 3の画像 3
    • Work your way around the perimeter of the shield, prying up intermittently, until you can remove it completely.
  18. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 18、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 18、 2の画像 2
    • Remove the heatsink shield.
  19. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the cooling fan: 手順 19、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the cooling fan: 手順 19、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the cooling fan: 手順 19、 3の画像 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
    • Use a pair of tweezers to pull the fan cable straight out of the connector.
  20. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink screws: 手順 20、 1の画像 1
    • Use a T3 Torx driver to remove the ten screws securing the heatsink:
    • Two 2.5 mm screws
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
  21. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 21、 1の画像 1
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern.
  22. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Clear the alignment peg: 手順 22、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Clear the alignment peg: 手順 22、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Clear the alignment peg: 手順 22、 3の画像 3
    • Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
    • Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
  23. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink: 手順 23、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink: 手順 23、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the heatsink: 手順 23、 3の画像 3
    • Remove the heatsink.
    • If the heatsink feels stuck to the CPU, gently wiggle it side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes are susceptible to creasing.
  24. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reapply thermal paste: 手順 24、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reapply thermal paste: 手順 24、 2の画像 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
  25. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard shields: 手順 25、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard shields: 手順 25、 2の画像 2
    • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
    • Use an opening tool to pry up an edge of the metal shield covering the right side of the motherboard.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Remove the shield.
  26. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 26、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 26、 2の画像 2
    • Repeat the previous step to remove the second shield from the left side of the motherboard, closest to the CPU.
  27. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the right speaker: 手順 27、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the right speaker: 手順 27、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the right speaker: 手順 27、 3の画像 3
    • Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
  28. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the Surface Connect port: 手順 28、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the Surface Connect port: 手順 28、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the Surface Connect port: 手順 28、 3の画像 3
    • Use an opening tool to flip open the gold locking arm on the Surface Connect port's motherboard connector.
  29. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 29、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 29、 2の画像 2
    • Grip the Surface Connect port cable and pull it away from its connector to remove it.
  30. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the left speaker: 手順 30、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the left speaker: 手順 30、 2の画像 2
    • Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
  31. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the display connector shields: 手順 31、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the display connector shields: 手順 31、 2の画像 2
    • Use an opening tool to pry up the black shield covering the right bank of display connectors.
    • Repeat at different points around the shield until it becomes loose.
  32. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 32、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 32、 2の画像 2
    • Repeat the previous step to remove the remaining shield from the left bank of display connectors.
  33. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the display cables: 手順 33、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the display cables: 手順 33、 2の画像 2
    • Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
  34. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 34、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 34、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 34、 3の画像 3
    • Disconnect the three remaining display connectors.
  35. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 35、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Reassembly tip: 手順 35、 2の画像 2
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case.
  36. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the antenna cable: 手順 36、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the antenna cable: 手順 36、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Disconnect the antenna cable: 手順 36、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to grip the antenna cable close to its base.
    • Pull straight up to disconnect the cable.
  37. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard bracket: 手順 37、 1の画像 1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
  38. Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 38、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement: 手順 38、 2の画像 2
    • Use a pair of tweezers to remove the motherboard bracket.
  39. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard screws: 手順 39、 2の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard screws: 手順 39、 2の画像 2
    • Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
    • Optionally, to simplify motherboard removal, use a T3 Torx driver to remove the three screws securing the port bracket, then remove the bracket.
  40. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard: 手順 40、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard: 手順 40、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the motherboard: 手順 40、 3の画像 3
    • Use your fingers to lift and remove the motherboard.
    • If the motherboard feels stuck, slide the motherboard to the right so the I/O ports clear their cutouts on the chassis.
    • Ensure the two screwpost braces underneath the motherboard don't get lost during removal.
  41. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Check cables during reassembly: 手順 41、 1の画像 1
    • When you reinstall the motherboard, verify that no cables get trapped under the board as you lower it into place. Check each of the five locations carefully:
    • Four display cables
    • Antenna cable
    • Left speaker cable
    • Surface Connect cable
    • Right speaker cable
  42. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the headphone jack screw: 手順 42、 1の画像 1
    • Use a T3 Torx driver to remove the 2.6 mm screw securing the headphone jack.
  43. Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the headphone jack: 手順 43、 3の画像 1 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the headphone jack: 手順 43、 3の画像 2 Microsoft Surface Laptop 3 15" Headphone Jack Replacement, Remove the headphone jack: 手順 43、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to lift the headphone jack up and over its screw peg.
    • Pull the headphone jack away from the edge of the chassis to remove it.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
作成者
1人の作成者と共同作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
135,488 ポイント
371のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,410のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 774
