メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Surface Book 2 15" Rear Camera Replacement
必要な工具と部品
  1. Microsoft Surface Book 2 15" Rear Camera Replacement, Motherboard: 手順 1、 1の画像 1
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
    FixBotに聞いてみる
    コメントを追加
  2. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 2、 2の画像 1 Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 2、 2の画像 2
    • Take a paper clip and unfold it.
    • Place the paper clip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
    FixBotに聞いてみる
    コメントを追加
  3. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 3、 1の画像 1
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
    FixBotに聞いてみる
    コメントを追加
  4. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 4、 1の画像 1
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
    FixBotに聞いてみる
    コメントを追加
  5. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 5、 2の画像 1 Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 5、 2の画像 2
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 6、 2の画像 1 Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 6、 2の画像 2
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
    FixBotに聞いてみる
    コメントを追加
  7. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 7、 1の画像 1
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
    FixBotに聞いてみる
    コメントを追加
  8. Microsoft Surface Book 2 15" Rear Camera Replacement, Front Camera: 手順 8、 1の画像 1
    • After lifting the motherboard, locate the two cameras near the center of the motherboard.
    • Unplug front camera (right side) from the motherboard (lift carefully).
    FixBotに聞いてみる
    コメントを追加
  9. Microsoft Surface Book 2 15" Rear Camera Replacement, Rear Camera: 手順 9、 1の画像 1
    • In the top left-hand corner of the tablet is where the camera sits.
    • Unscrew the T3 torx screw.
    FixBotに聞いてみる
    コメントを追加
  10. Microsoft Surface Book 2 15" Rear Camera Replacement: 手順 10、 1の画像 1
    • Unplug the camera from the connector and remove.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Colton Almeida
メンバー登録日: 03/13/23
172 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-3, Petersen Spring 2023 UMass Dartmouth, Team 3-3, Petersen Spring 2023人のメンバー
UMASSD-PETERSEN-S23S3G3
4 メンバー
23のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 643
