メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Merch Source Projector Entertainment II Motherboard
必要な工具と部品
    1. Merch Source Projector Entertainment II Motherboard, Outer Casing: 手順 1、 2の画像 1 Merch Source Projector Entertainment II Motherboard, Outer Casing: 手順 1、 2の画像 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      FixBotに聞いてみる
      コメントを追加
    2. Merch Source Projector Entertainment II Motherboard: 手順 2、 1の画像 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      FixBotに聞いてみる
      コメントを追加
    3. Merch Source Projector Entertainment II Motherboard: 手順 3、 2の画像 1 Merch Source Projector Entertainment II Motherboard: 手順 3、 2の画像 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      FixBotに聞いてみる
      コメントを追加
    1. Merch Source Projector Entertainment II Motherboard, Motherboard: 手順 4、 2の画像 1 Merch Source Projector Entertainment II Motherboard, Motherboard: 手順 4、 2の画像 2
      • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
      FixBotに聞いてみる
      コメントを追加
    2. Merch Source Projector Entertainment II Motherboard: 手順 5、 2の画像 1 Merch Source Projector Entertainment II Motherboard: 手順 5、 2の画像 2
      • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
      • Be sure not to damage any of the wires atached to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    3. Merch Source Projector Entertainment II Motherboard: 手順 6、 2の画像 1 Merch Source Projector Entertainment II Motherboard: 手順 6、 2の画像 2
      • Solder off all of the connections on the motherboard with a soldering iron.
      • Once connections are soldered off, the motherboard should be detached and ready for replacement.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
      • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Michael Tan
メンバー登録日: 01/08/15
590 ポイント
3のガイドは作成済み
3件のガイドコメント
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - 返信 共有
Where can I get parts for the projector? I think my board is cooked.
Delgtm - 返信 共有
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 42
今までの合計 2,413
