メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Main Board Replacement
必要な工具と部品
  1. Main Board Replacement, Exterior Housing: 手順 1、 3の画像 1 Main Board Replacement, Exterior Housing: 手順 1、 3の画像 2 Main Board Replacement, Exterior Housing: 手順 1、 3の画像 3
    この手順で使用する道具:
    iOpener
    $24.95
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
    FixBotに聞いてみる
    コメントを追加
  2. Main Board Replacement, Lower Half Casing: 手順 2、 3の画像 1 Main Board Replacement, Lower Half Casing: 手順 2、 3の画像 2 Main Board Replacement, Lower Half Casing: 手順 2、 3の画像 3
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
    FixBotに聞いてみる
    コメントを追加
  3. Main Board Replacement: 手順 3、 3の画像 1 Main Board Replacement: 手順 3、 3の画像 2 Main Board Replacement: 手順 3、 3の画像 3
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
    FixBotに聞いてみる
    コメントを追加
  4. Main Board Replacement, Preliminary Main Board: 手順 4、 2の画像 1 Main Board Replacement, Preliminary Main Board: 手順 4、 2の画像 2
    • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
    FixBotに聞いてみる
    コメントを追加
  5. Main Board Replacement: 手順 5、 1の画像 1
    • Peel away the black tape covering the red wires that connect to the PCB.
    FixBotに聞いてみる
    コメントを追加
  6. Main Board Replacement: 手順 6、 1の画像 1
    • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
    • Slowly lift the PCB away from the rest of the device
    • Remove the ribbon by first removing the brown insert piece from the connector on the button board
    • Pull the ribbon out of the connector on the button board by the blue tab.
    FixBotに聞いてみる
    コメントを追加
  7. Main Board Replacement: 手順 7、 1の画像 1
    • Carefully disconnect the white 11-pin connector from the main board.
    • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
    FixBotに聞いてみる
    コメントを追加
  8. Main Board Replacement, Main Board: 手順 8、 1の画像 1
    • Peel away the tape holding down the wires between the main board and the DC power and 3.5 mm audio jack board.
    FixBotに聞いてみる
    コメントを追加
  9. Main Board Replacement: 手順 9、 1の画像 1
    • Remove the two 3-pin connectors from the DC power and 3.5 mm audio jack board.
    FixBotに聞いてみる
    コメントを追加
  10. Main Board Replacement: 手順 10、 1の画像 1
    • Remove the black tape holding down the four wires connecting the main board to the upper half of the device.
    FixBotに聞いてみる
    コメントを追加
  11. Main Board Replacement: 手順 11、 1の画像 1
    • Carefully peel away the black melted plastic that covers the connection points from the four wires to the main board.
    • Make sure not to pull any of the wires out. This will make soldering them back on later more difficult. To avoid this, it may be easier to peel the melted plastic away in small chunks.
    FixBotに聞いてみる
    コメントを追加
  12. Main Board Replacement: 手順 12、 1の画像 1
    • Desolder the two red and two black wires from the main board, which will completely free the main board from the rest of the assembly.
    • You can refer to iFixit's guide or this informative video for more information on soldering.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Jackson McKay
メンバー登録日: 04/22/14
124 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G50
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 941
