メインコンテンツにスキップ
MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換
必要な工具と部品
  1. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, 下部ケースのネジを外す: 手順 1、 1の画像 1
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I use a magnetic mat and place the screws in order on that :)
    Cary B - 返信
  2. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, 下部ケースを持ち上げて外す: 手順 2、 1の画像 1
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - 返信
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, バッテリー: 手順 3、 1の画像 1
    • 作業前の注意点として、放電を防ぐためロジックボードからバッテリーコネクターの接続を外してください。
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    gansodesoyaからの引用:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 返信
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 返信
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 返信
  4. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, ディスプレイ: 手順 4、 3の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, ディスプレイ: 手順 4、 3の画像 2 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, ディスプレイ: 手順 4、 3の画像 3
    • スパッジャーの平面側先端を使って、右側スピーカーケーブルコネクター/サブウーファーをロジックボード上のソケットから外して持ち上げます。
    • 画像に示したようにコネクターの下から持ち上げてください。ソケット自体に接触しないでください。ロジックボードからソケットをアクシデントで外してしまうことがあります。
    Please Be Carefully With This Step, Because I Had To Resolder It Back To The Logic Board. But There Is A Black Foam Piece Over The Cable You Have To Pry Up, Lift The Foam Piece And Then Try To CAREFULLY Pry Cable Connector
    BWilliams842 - 返信
  5. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 5、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 5、 2の画像 2
    • カメラケーブルを水平にスライドさせて、ソケットから外します。
    • ケーブルをロジックボードの表面と平行に、光学ドライブの方向へ引きます。まっすぐ上に引っ張らないでください。コネクタが破壊されます。
    • ロジックボードにカメラケーブルがスライドして外れないように小さなプラスチック製リテイナー が付けられている場合は、ロジックボードから慎重に剥がしてください。必要に応じて、ヘアードライヤーやヒートガンで少し熱を加え、固定されている接着剤を柔らかくしてください。リテイナーを付けたまま、無理にケーブルを外さないでください。
    • それでも問題がある場合は、スパッジャーの先でコネクタの両側を押し、ソケットからゆっくりと "歩く"ように外していきます
    Be careful to the piece of plastic that prevents camera cable failing out its socket! Do not force connector! Look at plastic before attempting to remove connector Plastic is partially covered by cdrom flat connector at right of camera cable connector
    Silvio - 返信
    This step is unnecessarily tricky. I’ve tried to make it better by adding images highlighting the plastic stopper thingy and showing a clear arrow of the direction the cable should be pulled.
    However, simply pulling the cable may not be enough to remove it. It sure wasn’t for me. I think there ought to be a close-up of the two little nubbins on the sides of the plug which one uses to wiggle it loose from the connector by gently prying with a tiny flathead screwdriver. I didn’t add that tip because (a) it would have made the instructions longer, (b) I didn’t think to take a photo of it, and (c) using a screwdriver carelessly next to the logic board could scratch or break components on the motherboard. A guitar pick or very small spudger might work.
    hackerb9 - 返信
    @hackerb9 Thanks for your edits and comments! I took some additional shots and tried to clean this up a little for everyone. There should be a lot less confusion now. Interestingly, neither of the two MacBook Pros used for these guides had the plastic retainer piece you folks mentioned, but I left that image in a link so everyone can still see what it looks like if needed.
    Jeff Suovanen -
    Thanks for incorporating some of my edits and for taking new photos.
    Are you the one who took the original photographs? If so, you did originally have the hard plastic retainer as it was in those photos, just obscured by your thumbnail. The glue on the retainer allows it to shift a bit, so it's possible you took out the cable and knocked off the retainer without noticing it.
    Your two frame animation of pulling out the plug is helpful to show the proper direction. Given the number of people who have destroyed their MacBooks from this procedure, I think we should do even better. The instruction would be clearer if it said, “Disconnect the camera cable by sliding it horizontally out of its socket.”
    Also, if you can post a link to a picture without fingers in the shot, I will add an arrow showing the proper direction. (I would have added it to the original, but visually it would have gone through your fingers.)
    hackerb9 - 返信
    P.s. this isn't as important, but where did you hear the tip about the hairdryer? I'd leave that out as firmly peeling it up works fine.
    hackerb9 -
    Negative, I’m not the original photographer. You’re right, I do see the retainer in some of the previous photos, although it wasn’t in any of the images for this particular step. May have been an oversight on the part of the original author! So I’m glad you caught it. I updated the verbiage as you requested. Don’t worry about adding arrows—at this point, if someone ignores both the images and the multiple warnings in the text, that’s no longer a fault with the guide. The heat/hairdryer tip is standard practice for anything that’s secured with adhesive—I hardly ever work on a MacBook of any vintage without using a heat gun at least a couple times. It may not be strictly necessary, but the result is much cleaner and it reduces the risk of accident.
    Jeff Suovanen -
  6. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 6、 1の画像 1
    • 光学ドライブの回路からカメラデータケーブルを巻き戻します。
  7. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 7、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 7、 2の画像 2
    • 上部ケースの右側スピーカーとカメラデータケーブルを留めている次のネジを外します。
    • 8 mmプラスネジー2本
    • 4mm プラスネジー1本
    • 8 mmプラスネジのうち1本はカメラケーブルのグランドループの中に留められています。
    • サブウーファーの下からカメラのケーブルブラケットをスライドしてコンピューターから取り出します。
  8. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 8、 3の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 8、 3の画像 2 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 8、 3の画像 3
    • ディスプレイデーターケーブルロックに留められているプラスチックプルタブを掴み、コンピューターの DC-in側に向けて巻きます。
    • ディスプレイデーターケーブルコネクターをソケットからまっすぐ引き離します。
    • コネクターをソケットからまっすぐ持ち上げるのではなく手前に引いてください。
    Well, my display ended up looking like this after the repair:
    http://i1106.photobucket.com/albums/h366...
    As you can see, there was a light/dark banded pattern along the bottom of the screen, corresponding to the LCD's backlight. In my case it was also accompanied by a constant high pitched whistling noise. I swear to anything that's holy, it was not coming from the fan or the speaker, but rather the motherboard itself.
    Anyway, both these problems went away when I disconnected and reconnected the connector at this stage. I'm saying this on the off chance it helps someone else.
    Jonty Levine - 返信
    It's not to clear but there is a piece of spring steel that rotates away from the main (circuit board side) of the connector....this piece sort of hugs the parameter of the screen cable locking it to the circuit board...both arms wrapped around your brother....looking closely (10x magnifier) at this cable one of the gold connections is slightly oxidized---my display arbitrarily flickers and this symptom is lessened as the temperature increases...I suspect this is the cuase of the screen flashing on/off
    brian62 - 返信
  9. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 9、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 9、 2の画像 2
    • 上部ケースに留められたディスプレイデータケーブルブラケットから次のネジを2本外します。
    • 7 mmプラスネジー1本
    • 5 mmプラスネジー1本
    • 上部ケースからディスプレイデータケーブルのブラケットを持ち上げます。
  10. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 10、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 10、 2の画像 2
    • 上部ケースに留められた2つのディスプレイブラケットから 6.5 mm外付けトルクスネジを2本ずつ(計4本)を外します。
    • Mid 2009モデルはT6トルクスドライバーが必要です。一方でMid 2010モデルはT8ドライバーが必要です。
    Hey folks, regarding the screw/driver sizes: there are separate guides for the Mid 2010 model with the T8 screws. Always use the correct guide for your model to avoid confusion, stripped screws, etc. Hope this helps!
    Jeff Suovanen - 返信
  11. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 11、 1の画像 1
    • MacBook 本体を開きます。ディスプレイが上部ケースに対して直角になるように開いてください。
    • 画像に示したようにMacBookをテーブルに対して垂直に立てます。
    • 左手でディスプレイと上部ケースを同時に持ちながら、トルクスドライバーでディスプレイ下部のブラケットから残りの6.5mmネジを外します。
  12. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 12、 1の画像 1
    • ディスプレイと上部ケースを同時に左手で押さえてください。手で固定せずに作業をするとディスプレイ/上部ケースが落ちて外れてしまい、各コンポーネントにダメージを与えてしまうことがあります。
    • 上部ケースに留めれらたディスプレイから最後の残りの6 mm トルクスネジを外します。
    Removing the screen assembly this way, with the computer standing on edge, is needlessly risky and difficult. By the 5th or 6th time I did this procedure (of perhaps a hundred), it dawned on me that there’s a way, way easier method for the whole lid removal job: 1. After removing the bottom cover and disconnecting power, hang the open laptop, keyboard down, facing away, over the edge of your work table with the lid assembly hanging down, monitor facing toward the table and pushed against the table edge. (If you’re klutzy, tape the main body to the table so it can’t slide around.) 2. With the unit positioned this way, you can easily disconnect the various cables & remove the 6 hinge screws. Now the lid assembly will just be hanging, easy to lift away from the main body without difficulty or danger. 3. Reverse this to put it back together.
    clinton - 返信
    Nice tip, Clinton! I’ll have to try that next time. Do you have photos of how it is done so this guide can be updated?
    hackerb9 -
  13. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 13、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 13、 2の画像 2
    • 右手で上部ケースを持ち、ディスプレイの上部に向けてわずかにずらしながら押し出します。すると上部ディスプレイブラケットから上部ケースの先端が外れます。
    • ディスプレイを上部ケースから少しずらして外します。
  14. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 14、 1の画像 1
    • ブラケットやケーブルが絡まないように気をつけながら、上部ケースからディスプレイを持ち上げて外します。
    Re-assembly hint: Laying the base, keyboard down, on a table top with the hinge side over the edge about 1/2" toward you is a more stable position for re-assembly than trying to do this up on its edge. This has the added benefit of being able to reinsert the torn screws vertically.
    Pete H - 返信
    May be in the wrong place but then please direct me. At this step, can I just take off the upper half (meaning the screen, LCD, and top housing shell in one) and simply replace it with another upper half of the same edition???
    cmackay13stmarys - 返信
    Yes, you can. Thanks what I'm doing now. :)
    Mike Mayaka -
  15. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, フロントディスプレイガラス: 手順 15、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換, フロントディスプレイガラス: 手順 15、 2の画像 2
    • 次の手順では、外側の黒いボーターに留められている圧着剤を温めて、柔らかくしてください。圧着剤が付けれている範囲は2番目の画像で赤く囲まれています。
    • ヒートガンの温度を低温にして、ガラスパネルの上側右端付近の黒いボーダーに熱を当てます。
    • 常にディスプレイガラス周辺の柔らかいゴム製ストリップから離してください。ゴムを温めてしまうと若干溶けてしまいます。ゴムの仕上がりが今あるマット感から光沢感へと変わってしまいます。過熱されたゴムに触ってしまうと永久に変形してしまいます。
    • 熱が当てられているため、ガラスパネル内側や/または、LCDの外側に水滴が発生することがあります。ディスプレイからガラスを取り出した際に、ガラスクリーナーで水滴を拭き取ってください。
    Heating rubber strip it becomes glossy You can turn it to matte using ultrafine sandpaper (very ultrafine!!!) P2500
    Silvio - 返信
    Great piece of advice. Thank you!
    Brian -
    With a lot of heating, for me, it was very hard to get the glass to separate from the case. I had better luck starting from the bottom right as I could grip better onto the case. Three mistakes I made:
    1. Once I got the glass separated, I probably didn't heat sufficiently as I was going around and the glass broke. That made the rest of the procedure miserable. Lesson: pull very gently.
    2. I must have touched one of the tiny bits of glass that fell on the LCD and it scratched the actual screen. :-(. Lesson: vacuum the pieces as you go and be very careful when touching the LCD.
    3. I somehow overheated the LCD screen at the top left and right corners and now the display is all wonky and faded at the corners. Not sure what the lesson is here.
    Athanassios Diacakis - 返信
    First, if using a hair dryer, what setting should that be operated at? It would be much cooler than the heat gun, right?
    Second, the iFixit basic set comes with a small, clear suction cup. Would that be sufficient for this project, or does it require the stronger pull of the other cups?
    Finally, must I reapply adhesive to the case when replacing the glass? Does the original remain tacky and re-bond on assembly?
    contact - 返信
    It's been a while since you asked, but since no one answered and someone else may have the same questions:
    Hair dryers vary a lot, depending on wattage. I would start on low or med, and work my way up to high if necessary. I'd keep the fan on the lowest setting.
    The little suction cup is for removing screens like the iMac, which just uses magnets, and possibly an iPad or iPhone. I would not want to use that for this project, get something about 2" wide with a decent handle.
    The screen should have the double sided glue tape already applied, just remove the backing. I wouldn't get glass that doesn't have the tape on it, big waste of time with little savings in cost.
    Jeff Kamis
    maccentric -
    All I can say for this is don't be tempted to hold the heat gun too close. I ended up burning my LCD the first time I did it and having to replace that when all I was looking to do was replace the cable. I got the glass off holding it about 4/5 inches from the screen and being patient (it took about 5/10 minutes in the end).
    Nick - 返信
    The tape is very sticky and the glass is very fragile but at the same time fairly flexible.....I ended up breaking the glass ans it turned out to be a mess picking up the shards....but in the end a new glass is not too costly. the implication is that heating melts the glue but it is really just double stick tape.....there are some "youtube" videos that are worth a look but I would suggest using guitar picks and not a putty knife which creates a point load that breaks the glass....wear safety glasses!!
    brian62 - 返信
    Be ready to replace the glass (good thing mine was already broken, I ordered one). Wear surgery gloves and protective glasses. Trust your nose, if it smell melted plastic, it’s a good clue to stop the heat.
    Sebastien CHAPUIS - 返信
    It's more easy to do this step before removing the LCD. You have more control of the LCD and is more easy to remove the Glass.
    Felix - 返信
    If you have a glass cover that is severely cracked then the heating gun and suction cup procedure really doesn’t work. Suction cups won’t hold and the already broken glass doesn’t lift. Here’s what I did that made the job easier. Using 2 inch wide transparent packing tape I laid it along the perimeter of the display but not covering the rubber edge. Then I used a 1/4 inch wood carving tool and very carefully removed the glass and 2 sided tape around the metal border. Use as your guide picture 2 in this step that shows where the camera and cable is located. Where the camera is located in the top center the 2 sided tape isn’t located so you can easily lift the glass. The camera cable runs up the right side in a trough in the metal border so when lifting the tape and glass in this area just keep the sharp end flat and it is wide enough it won’t dip into the trough and damage the cable. The tape was very helpful because it kept the glass from splintering and going everywhere.
    joe lochner - 返信
  16. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 16、 3の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 16、 3の画像 2 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 16、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • パネルが十分に温まったら、高荷重用の吸盤カップをディスプレイガラスの上部右側端に装着します。
    • ディスプレイガラスの端に付けられているゴム製ストリップの上に吸盤カップを装着しないでください。
    • iFixit製の吸盤カップを装着するには、まず吸盤カップを定位置に置いて可動式ハンドルをガラスパネルを平行にして開いた状態にします。吸盤カップがガラス上に軽く固定されたら可動式ハンドルを持ち上げて双方が平行になるまでまっすぐ立てます。
    • ディスプレイアセンブリからディスプレイガラスをゆっくりと丁寧に引き上げます。
    • ガラスの上部端を持ち上げたら(3番目の画像を参照)、パネルの端が持ち上がるまでこの手順を1–2回繰り返してください。
  17. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 17、 3の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 17、 3の画像 2 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 17、 3の画像 3
    • ディスプレイガラスの端を持ち上げて、ディスプレイアセンブリとの間に作られた隙間にスパッジャーの先端を差し込みます。
    • スパッジャーの平面側先端を使って、ディスプレイにフロントガラスを固定している圧着剤を丁寧にこじ開けます。
    • ディスプレイの上部と右端のコーナーに沿ってスパッジャーをスライドし、右側上部からわずかにガラスパネルを引き上げます。
  18. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 18、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 18、 2の画像 2
    • ヒートガンを使ってフロントガラスパネルの右側に沿って黒いストリップの下に付けれられた圧着剤を温めて柔らかくします。
    • 吸盤カップをフロントガラスパネルの右側に沿って装着します。
    • スパッジャーの平面側先端を使って、ディスプレイアセンブリの残りからガラスパネルを引き離しながら、ガラスパネルを引き上げます。
    • ディスプレイから外れるまで、引き続きフロントディスプレイガラスの右側端に沿ってスパッジャーをスライドします。
    • ギターのピックやその他薄いプラスチック製のシート状のものを上部右側コーナーに差し込むと、フロントガラスパネルがディスプレイアセンブリに再装着しないように保護してくれます。
    I ended up breaking my glass panel due to using the spudger. I think if you use something more like a small putty knife you will do better. The spudger puts a lot of pressure in a small spot while the putty knife would put a little pressure over a larger area. Also, if you do break the glass, be sure to get ALL of the broken bits off before putting the new one on. Also, watch out for those broken bits as they tend to penetrate skin quite easily, and stay there for days!
    mastover - 返信
  19. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 19、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 19、 2の画像 2
    • ヒートガンを使って、ガラスのディスプレイパネル上部端の黒いストリップ下に留められた圧着剤を温めて柔らかくします。
    • ガラスのディスプレイパネルの上部端付近に吸盤カップを装着してディスプレイからガラスパネルを引き上げます。
    • ガラスパネルの上部端に沿って作業を進めて、スパッジャーの平面側先端を使いながら必要に応じて圧着剤を剥がします。
  20. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 20、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 20、 2の画像 2
    • ディスプレイパネルの上部左側コーナー付近の黒いストリップ下に留められた圧着剤を柔らかくするため、ヒートガンを使います。
    • ディスプレイパネルの上部左側コーナー付近に吸盤カップを装着します。
    • 吸盤カップを引き上げて、スパッジャーの平面側先端をガラスディスプレイパネルに差し込み、ディスプレイアセンブリから丁寧にこじ開けます。
    • 上部左側コーナーがディスプレイから外れたら、ギターピックや他の薄いプラスチック製シートを挟んでディスプレイアセンブリにガラスが再装着するのを防ぎます。
  21. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 21、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 21、 2の画像 2
    • ヒートガンやヘアドライヤーを使って、正面ガラスパネルの左側に沿って黒いストリップ下に付けられた圧着剤を温めて柔らかくします。
    • 正面ガラスパネルの左側に沿って吸盤カップを装着します。
    • スパッジャーの平面側先端を使ってディスプレイの残りからガラスを外すためにこじ開けている間、ガラスパネルを引っ張り続けます。
    • ディスプレイからガラスが外れるまで、フロントディスプレイガラスの左側端に沿ってスパッジャーを動かしながら作業を続けます。
  22. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 22、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 22、 2の画像 2
    • ここで上部、左、右側のガラスがディスプレイから外れました。ゆっくりとガラスパネルの上部端を丁寧に持ち上げてディスプレイを外側に外します。
    • 必要に応じてスパッジャーの平面側先端を使い、ディスプレイアセンブリからガラスディスプレイパネルの底側端を外してください。
    • 再組み立ての前に、ガラスディスプレイパネルとLCDの内側を綺麗に拭き取ってください。内部に残された指紋や埃はデバイスの稼働中、視界を遮ることがあります。
  23. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 23、 2の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 23、 2の画像 2
    • 工場出荷時のオリジナルのガラスを再利用される場合はこの手順をスキップしてください。
    • プラスチック製開口ツールの先端をディスプレイガラスとカメラブラケットの間に差し込み、ディスプレイガラスから剥がすためにカメラブラケットの周辺でこじ開けます。
    • 再組み立ての前に、交換用フロントディスプレイガラスにカメラブラケットを装着したか確認してください。
  24. MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 24、 3の画像 1 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 24、 3の画像 2 MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換: 手順 24、 3の画像 3
    • ガラスの交換作業中、カメラケーブルがガラスパネル上の圧着剤に付着することがあります。パネルを持ち上げてカメラボードからカメラケーブルの接続を外してください。それでもカメラケーブルがカメラボードに付着している場合は、この手順をスキップしてください。
    • ケーブルを再接続するには、まずスパッジャーの先端んを使ってカメラケーブルのZIFソケットを覆っているフォーム製テープの一部を取り出します。
    • スパッジャーの先端を使って、カメラケーブルソケット上のZIFケーブルリテイナーを取り出します。
    • カメラケーブルをカメラボード上のソケットに装着し、スパッジャーの先端を使って、カメラケーブルをロックして固定し、ZIFケーブルリテイナーを上から押して締めます。
    • カメラケーブルソケットをカバーするテープを再度取り付けてください。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
52 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
10人の作成者と共同で作成されました。
Walter Galan
694,692 ポイント
1,203のガイドは作成済み
コメント 1 件
This guide needs to be replicated / linked on to all the other A1286 13-inch Unibody models as it was done with the 2010 model. The screens are the same for each year of the A1286 generation from 2009, 2010, early 2011, late 2011, and 2012.
Ideally, it could be really helpful if the staff team can improve the article; improve on the steps outlined; using the feedback received in the comments - e,g, safer ways to handle broken glass, use of solvents like alcohol or acetone to dissolve / neutralise the adhesive seal, and ways to preserve the rubber lining, the LCD panel itself, and the additional circuitry & cabling underneath.
Jon T. - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 56
今までの合計 91,671
