メインコンテンツにスキップ
MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換
必要な工具と部品
  1. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換, 下部ケースのネジを外す: 手順 1、 1の画像 1
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I use a magnetic mat and place the screws in order on that :)
    Cary B - 返信
  2. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換, 下部ケースを持ち上げて外す: 手順 2、 1の画像 1
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - 返信
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換, フットパッド: 手順 3、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換, フットパッド: 手順 3、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換, フットパッド: 手順 3、 3の画像 3
    • 壊れたりダメージの入ったフットパッドを取り外します。
    • フットパッド用のホールに残っている壊れたフットパッドのパーツをすべて取り出します。
    • ピンセットを使って、古いフットパッドから残っている接着テープを綺麗に剥がします。
  4. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 4、 1の画像 1
    • 残りの接着剤を取るため、接着剤リムーバーを使ってフットパッド用パッドで磨きます。
    On my mid-2009 unibody MacBook Pro, there were thin, circular, black cloth pieces inside the case, covering the holes where the feet came through. I had to remove this tape, in order to push the feet through.
    Edward Horner - 返信
  5. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 5、 1の画像 1
    • クリーナーで残っている残りの接着剤を取るため、アルコールパッドを使ってフット部分をワイプします。
  6. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 6、 1の画像 1
    • 交換用のフットパッドからプラスチックの裏地を剥がします。
  7. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 7、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 7、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 7、 3の画像 3
    • フットパッドのパッド内側の位置に新しい交換用パッドを揃えます。
    • 足部分の凹み位置にフットパッドの外周部分がきちんと揃っているか確認します。
    • 定位置を確認しながらフットパッドを取り付けます。
    • ピンセットを使って下部ケース内側と位置を揃えます。
  8. MacBook Pro 13インチ Unibody Mid 2010 フットパッドの交換: 手順 8、 1の画像 1
    • 指でしっかりとフットパッドを押さえ、約30秒間接着剤を固定しながら装着します。指でフットを抑えながら、カバーの反対側をサポートします。
    • 壊れたりダメージの入ったフットパッドがあれば、最後の6手順を繰り返してください。
    Support the rear feet from inside with your other hand before pressing down on new foot. Failure to do so may damage the plastic air grille inside the rear of the lower case. See the photos in step 3 above.
    hterlecki - 返信
    My A1278 hasn't got holes in the backplate?
    The feet just seem to be stuck on with adhesive.
    Do I still have to unscrew the back?
    Regards,
    Rob.
    Rob Haygarth - 返信
    Hi Rob,
    If the backplate doesn’t have the holes, you can still use the feet by just glueing them on. You would not have to open the backplate.
    Arthur Shi -
    I have been told that if you are using adhesive, you should follow these steps and remove the bottom.
    This way, adhesive doesn’t get inside the machine.
    Larry D Turner - 返信
    Hi Larry,
    That is definitely true, if you are adding liquid adhesives. The feet we sell come with adhesive pre-installed on the feet. All you have to do is peel and stick!
    Arthur Shi -
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
25 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,326 ポイント
416のガイドは作成済み
2 件のコメント
Just wondering if melting the original pads from inside the case with a flame would help to fix them in place for a little longer.
vlada - 返信
I’d be a little wary of doing something like that. I don’t think it would help the pads stay in place very much, but it might make it really hard to clean the case when you do want to replace the pads. If you want to make the original pads last a little longer you can try pulling them off, cleaning off the old adhesive, and applying some new tape or glue.
Adam O'Camb -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 38
今までの合計 6,835
