メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Core Duo Display Replacement
必要な工具と部品
    1. MacBook Core Duo Display Replacement, Battery: 手順 1、 1の画像 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core Duo Display Replacement: 手順 2、 1の画像 1
      • Lift the battery out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core Duo Display Replacement, Memory Cover: 手順 3、 1の画像 1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core Duo Display Replacement: 手順 4、 1の画像 1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core Duo Display Replacement, Upper Case: 手順 5、 1の画像 1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core Duo Display Replacement: 手順 6、 1の画像 1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Core Duo Display Replacement: 手順 7、 1の画像 1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      FixBotに聞いてみる
      コメントを追加
    4. MacBook Core Duo Display Replacement: 手順 8、 1の画像 1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      FixBotに聞いてみる
      コメントを追加
    5. MacBook Core Duo Display Replacement: 手順 9、 1の画像 1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      FixBotに聞いてみる
      コメントを追加
    6. MacBook Core Duo Display Replacement: 手順 10、 1の画像 1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      FixBotに聞いてみる
      コメントを追加
    7. MacBook Core Duo Display Replacement: 手順 11、 1の画像 1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      FixBotに聞いてみる
      コメントを追加
    8. MacBook Core Duo Display Replacement: 手順 12、 1の画像 1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core Duo Display Replacement, Optical Drive: 手順 13、 1の画像 1
      • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core Duo Display Replacement: 手順 14、 1の画像 1
      • Remove the two Phillips screws from the front edge of the optical drive.
      • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Core Duo Display Replacement: 手順 15、 1の画像 1
      • Disconnect the orange optical drive ribbon cable from the logic board.
      FixBotに聞いてみる
      コメントを追加
    4. MacBook Core Duo Display Replacement: 手順 16、 1の画像 1
      • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
      FixBotに聞いてみる
      コメントを追加
    5. MacBook Core Duo Display Replacement: 手順 17、 1の画像 1
      • Disconnect the (once again) newly-revealed hard drive cable.
      FixBotに聞いてみる
      コメントを追加
    6. MacBook Core Duo Display Replacement: 手順 18、 1の画像 1
      • Peel up the foil tape between the fan and the optical drive.
      • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
      FixBotに聞いてみる
      コメントを追加
    7. MacBook Core Duo Display Replacement: 手順 19、 1の画像 1
      • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
      FixBotに聞いてみる
      コメントを追加
    8. MacBook Core Duo Display Replacement: 手順 20、 1の画像 1
      • Remove the 2.8 mm Phillips screw securing the optical drive.
      • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
      • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
      • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
      FixBotに聞いてみる
      コメントを追加
    9. MacBook Core Duo Display Replacement: 手順 21、 1の画像 1
      • Lift the Bluetooth antenna board from the right side of the optical drive.
      FixBotに聞いてみる
      コメントを追加
      • Deroute the hard drive cable from along the front of the optical drive.
      FixBotに聞いてみる
      コメントを追加
    10. MacBook Core Duo Display Replacement: 手順 23、 1の画像 1
      • Lift the front edge of the optical drive and slide it up and out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core Duo Display Replacement, C-Channel: 手順 24、 1の画像 1
      • Two 3 mm Phillips near the right speaker.
      • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
      • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core Duo Display Replacement: 手順 25、 1の画像 1
      • Lift the right speaker out of its housing and set it to the side.
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Core Duo Display Replacement: 手順 26、 1の画像 1
      • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core Duo Display Replacement, Display: 手順 27、 1の画像 1
      • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
      • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core Duo Display Replacement: 手順 28、 1の画像 1
      • Lift up on the black right speaker cable with one hand, and deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Core Duo Display Replacement: 手順 29、 1の画像 1
      • Deroute the silver microphone cable and gray display data cable from the tabs at the bottom of the subwoofer.
      FixBotに聞いてみる
      コメントを追加
    4. MacBook Core Duo Display Replacement: 手順 30、 1の画像 1
      • Remove the single 3.2 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
      FixBotに聞いてみる
      コメントを追加
    5. MacBook Core Duo Display Replacement: 手順 31、 1の画像 1
      • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board. (Pull vertically on all three.)
      FixBotに聞いてみる
      コメントを追加
    6. MacBook Core Duo Display Replacement: 手順 32、 1の画像 1
      • Remove the following 2 screws from the right hinge mount:
      • One 6 mm Phillips on the left side of the hinge mount.
      • One 10 mm Phillips on the right side of the hinge mount.
      • Lift the right hinge mount out of the computer.
      FixBotに聞いてみる
      コメントを追加
    7. MacBook Core Duo Display Replacement: 手順 33、 1の画像 1
      • Hold the display with one hand while removing the screws from the left hinge mount.
      • Remove the following 3 screws from the left hinge mount:
      • One 6 mm smaller diameter Phillips from the right side.
      • One 6 mm larger diameter Phillips from the middle.
      • One 10 mm Phillips from the left side.
      • Lift the left hinge mount out of the computer.
      FixBotに聞いてみる
      コメントを追加
    8. MacBook Core Duo Display Replacement: 手順 34、 1の画像 1
      • Grasp the display assembly on either side, and lift it up and out of the computer.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
87 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 73
今までの合計 140,618
