メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Core 2 Duo Hard Drive Replacement
必要な工具と部品
  1. MacBook Core 2 Duo Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    FixBotに聞いてみる
    コメントを追加
  2. MacBook Core 2 Duo Hard Drive Replacement: 手順 2、 1の画像 1
    • Lift the battery out of the computer.
    FixBotに聞いてみる
    コメントを追加
  3. MacBook Core 2 Duo Hard Drive Replacement, Memory Cover: 手順 3、 1の画像 1
    • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
    FixBotに聞いてみる
    コメントを追加
  4. MacBook Core 2 Duo Hard Drive Replacement: 手順 4、 1の画像 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
    FixBotに聞いてみる
    コメントを追加
  5. MacBook Core 2 Duo Hard Drive Replacement, Hard Drive: 手順 5、 1の画像 1
    • Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
    • The hard drive goes back into its compartment with the label facing down.
    FixBotに聞いてみる
    コメントを追加
  6. MacBook Core 2 Duo Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Remove the two black T8 Torx screws securing the silver bracket to the hard drive.
    • There are two types of screws on this caddy: one with a flange below the head of the screw, and one without. Make note that the screws without the flange go in the two holes closest to the SATA connector.
    FixBotに聞いてみる
    コメントを追加
  7. MacBook Core 2 Duo Hard Drive Replacement: 手順 7、 1の画像 1
    • Rotate the hard drive and remove the two black T8 Torx screws on the other side of the drive.
    FixBotに聞いてみる
    コメントを追加
  8. MacBook Core 2 Duo Hard Drive Replacement: 手順 8、 1の画像 1
    • Lift the silver metal hard drive bracket off the hard drive.
    • You'll need to transfer this metal bracket to your new hard drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
872 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
31件のガイドコメント
This upgrade is so easy. Just do it. Even your dad could do this.
After the upgrade to a 320 GB 7200 rpm, the MacBook (1.83 GHz Intel Core Duo A1181, with 2 GB of ram) works like a new computer. However, the fan comes on so easy - and stays on forever. Is this due to the increased speed of the hard drive? Is there a way to turn down the hard drive speed when used on AC power?
suselfunk - 返信 共有
The rubber guide came off on mine too. The mistake is that the screws without the flanges go on the outside edge of the Mac and the flange ones towards the inside. If you do it backwards it will pull the rubber guide off and then an otherwise effortless install will take a while longer to complete.
MarkBookPro - 返信 共有
it's really easy to do this - there's no need to pay someone else! thanks for this awesome tutorial.
andreahull - 返信 共有
Very simple and easy! The biggest challenge was the walk to Radio Shack in cold weather to go get a !#!@ torx! The OSX installation guide was also a big help.
rsimmons1980 - 返信 共有
Bought a Crucial M4 CT128M4SSD2 (128 GB SSD), removal was quick and easy. This was my wife's mac, I personally do not own Apple products. My challenge was that I had to erase the drive (which in the process re-formats the ssd) which got the install up and running.
russcrandall - 返信 共有
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 55
過去 30 日: 268
今までの合計 584,365
