メインコンテンツにスキップ
MacBook Air 13" Late 2020 Logic Board Replacement
必要な工具と部品
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  1. MacBook Air 13" Late 2020 Logic Board Replacement, Remove the lower case: 手順 2、 3の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement, Remove the lower case: 手順 2、 3の画像 2 MacBook Air 13" Late 2020 Logic Board Replacement, Remove the lower case: 手順 2、 3の画像 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  2. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the battery: 手順 3、 3の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the battery: 手順 3、 3の画像 2 MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the battery: 手順 3、 3の画像 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  3. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the audio board cable: 手順 4、 1の画像 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  4. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 5、 1の画像 1
    • Remove the audio board connector cover.
  5. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 6、 2の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement: 手順 6、 2の画像 2
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
  6. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the USB-C board cable: 手順 7、 1の画像 1
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector cover.
  7. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 8、 1の画像 1
    • Remove the USB-C connector cover.
  8. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 9、 2の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement: 手順 9、 2の画像 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  9. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the antenna bar connections: 手順 10、 1の画像 1
    • Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
  10. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 11、 1の画像 1
    • Remove the antenna cable cover.
  11. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 12、 3の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement: 手順 12、 3の画像 2 MacBook Air 13" Late 2020 Logic Board Replacement: 手順 12、 3の画像 3
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
  12. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 13、 1の画像 1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
  13. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 14、 1の画像 1
    • Remove the display cable connector cover.
  14. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 15、 2の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement: 手順 15、 2の画像 2
    • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
  15. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the trackpad cable: 手順 16、 1の画像 1
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
  16. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 17、 1の画像 1
    • Remove the trackpad cable cover.
  17. MacBook Air 13" Late 2020 Logic Board Replacement: 手順 18、 2の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement: 手順 18、 2の画像 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  18. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the left speaker cable: 手順 19、 3の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the left speaker cable: 手順 19、 3の画像 2 MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the left speaker cable: 手順 19、 3の画像 3
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
  19. MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the microphone cable: 手順 20、 3の画像 1 MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the microphone cable: 手順 20、 3の画像 2 MacBook Air 13" Late 2020 Logic Board Replacement, Disconnect the microphone cable: 手順 20、 3の画像 3
    • Use a pair of tweezers to peel back any tape covering the microphone cable connector.
    • Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
    • Slide the microphone cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  20. MacBook Air 13" Late 2020 Logic Board Replacement, Remove the logic board screws: 手順 21、 1の画像 1
    • Use a T5 Torx driver to remove the six screws securing the logic board to the upper case:
    • Three 3.5 mm screws
    • One 6.0 mm cushioned screw
    • Two 3.4 mm screws
  21. MacBook Air 13" Late 2020 Logic Board Replacement, Remove the logic board: 手順 22、 1の画像 1
    • Remove the logic board.
  22. MacBook Air 13" Late 2020 Logic Board Replacement, Check cables during reassembly: 手順 23、 1の画像 1
    • When you reinstall the logic board assembly, verify that no cables get trapped under the board as you lower it into place. Check each of the seven locations carefully:
    • Battery cable
    • Audio board cable
    • USB-C board cable
    • Antenna bar cables
    • Display cable
    • Trackpad cable
    • Left speaker and microphone cables
終わりに
Once you've completed your repair, your laptop may not power back on until connected to power.
17 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
100,437 ポイント
337のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
136 メンバー
15,154のガイドは作成済み
4 件のコメント
Thank you
How do we access the data on a board that is not working due to corrosion ? We have been informed that the SSD is integrated in the board so until same is working we cannot access the data.
Kiran Meettook Esq - 返信
Looking for the WiFi component?
Jens Erik Bech - 返信
alguien sabe si existe un adaptador para este tipo placa logica a sdd para?
madrigal26 - 返信
A strange question
Would you start a MacBook Air WITHOUT a battery, powering the board directly as if it were a desktop? 🤔
Does anyone know what voltage the battery cables provide?
Thank you.
Alquimista - 返信
コメントを追加
統計データ:
過去 24時間: 56
過去 7 日: 424
過去 30 日: 1,822
今までの合計 39,520
