はじめに
Use this guide to remove or replace the antenna bar in a Late 2020 MacBook Air (M1).
必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
Use a pair of tweezers to grip the antenna connector close to its base.
Pull straight up to disconnect the cable.
Repeat for the second antenna cable.
Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
Use a T5 Torx driver to remove the six screws securing the antenna bar:
Four 7.4 mm silver screws
Two 4.7 mm black screws
Insert the pointed end of a spudger into the gap between the antenna bar and display hinge.
Pivot the spudger against the hinge to pry up the end of the antenna bar.
Repeat for the other end of the antenna bar.
Once you've completed your repair, your laptop may not power back on until connected to power.
7 の人々がこのガイドを完成させました。
