メインコンテンツにスキップ
MacBook Air 11インチ Early 2015のロジックボードの交換
必要な工具と部品
  1. MacBook Air 11インチ Early 2015のロジックボードの交換, 下部ケース: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $11.99
    購入する
    • まず、コンピューターをシャットダウンし、柔らかい素材の表面上に天面を下にして置きます。
    • 以下の10本のネジを外します:
    • 星型ペンタローブネジ 8mm 2本
    • 星型ペンタローブネジ 2.5mm 8本
    • 星型ペンタローブネジを外す際に必要な特別ドライバーはこちらで購入できます。
    When you say:
    Remove the following ten screws:
    Two 8 mm 5-point Pentalobe screws
    Eight 2.5 mm 5-point Pentalobe screws
    Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
    Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
    Nerdily yours,
    Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
    larryleveen - 返信
    The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
    Michael Welham -
    I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
    Allen - 返信
    The magnetic mat is
    GERARD SZAREK -
    Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
    Frank O'Carroll - 返信
    A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
    Michael Mee - 返信
    Thank you for a really smart tip! I will be using that countless more times!
    Lilljedahl -
    I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
    It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
    I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
    AMG - 返信
    The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
    Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
    Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
    Hope this helps! -Dan
    danielwen -
    I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
    Robert Hermans - 返信
    Hi Robert!
    Try some techniques found in this stripped screw removal guide. Good luck!
    Arthur Shi -
    Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
    vensilver - 返信
    Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
    Arthur Shi -
    The smaller screws went in more easily when I put back all the screws along the hinge edge first.
    Rachel Slatkin - 返信
  2. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 2、 1の画像 1
    • ディスプレイと下部ケースの間に指を入れ、下部ケースを引き上げて外します。
  3. MacBook Air 11インチ Early 2015のロジックボードの交換, バッテリーコネクター: 手順 3、 2の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換, バッテリーコネクター: 手順 3、 2の画像 2
    • 作業中に部品がショートするのを防ぐためにバッテリーを取り外します。
    • スパッジャーの平面側先端を利用し、バッテリーコネクターを持ち上げてロジックボードのソケットから外します。
    • ロジックボードから外したコネクターのケーブルをわずかに曲げて、コネクター部分が誤ってソケットに接触しないようにします。
    When reassembling the connector wire needs to be bent to fit.
    GERARD SZAREK - 返信
  4. MacBook Air 11インチ Early 2015のロジックボードの交換, I/Oボードケーブル: 手順 4、 2の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換, I/Oボードケーブル: 手順 4、 2の画像 2
    • スパッジャーの平面側先端を使って、I/Oボード上の各ソケットから左右のI/Oボードケーブルコネクタを持ち上げます。
  5. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 5、 1の画像 1
    • I/Oボードケーブルを持ち上げて外します。
  6. MacBook Air 11インチ Early 2015のロジックボードの交換, ファン: 手順 6、 2の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換, ファン: 手順 6、 2の画像 2
    • スパッジャーの先端を使って、iSightカメラケーブルのコネクタの両側を慎重に押さえて、ロジックボード上のソケットからコネクタの接続を緩めます。
    • ソケットからコネクタを外す際は、慎重にずらしながら作業を行なってください。
  7. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 7、 2の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 7、 2の画像 2
    • ファンに留められた接着剤からiSightカメラケーブルを剥がします。
    Additionally it seems as though the display assembly I have is from an earlier model with a different built in camera. I don’t care if the camera works, could I chop the cord, power it up, and just no have a working camera?
    Aidan - 返信
  8. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 8、 2の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 8、 2の画像 2
    • スパッジャーの先端を使って、ファンケーブルのZIFソケット上の固定フラップを注意深く跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。
    Be sure you understand how the connector works, if you have to go and look up “apple ZIF connector” and watch a video. The one above flips up from where the tool is pointing at. Again do not damage the connector. Click the second picture to see this!
    joe - 返信
  9. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 9、 1の画像 1
    • 上部ケースをファンに固定している次の3本のネジを外します。
    • 5.5 mm T5トルクネジー2本
    • 4.6 mm T5トルクネジー1本
    • あるモデルによっては、このサイズの代わりに3.6 mm T5トルクネジが使用されています。
  10. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 10、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 10、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 10、 3の画像 3
    • ファンを持ち上げますが、上部ケースの底からファンを完全に取り出さないでください。
    • Airからファンを取り出す際に、ソケットからファンのリボンケーブルを慎重に引き抜いてください。
  11. MacBook Air 11インチ Early 2015のロジックボードの交換, ロジックボードアセンブリ: 手順 11、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換, ロジックボードアセンブリ: 手順 11、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換, ロジックボードアセンブリ: 手順 11、 3の画像 3
    • スパッジャーの平面側先端を使って両側のアンテナコネクタをAirPort/Bluetoothカード上のソケットから引き抜き、作業の邪魔にならないように動かします。
    Be very careful. When I did this - just as in the photo - I prised the top of the antenna connector off from the bottom of it, leaving me with only one functioning antenna.
    Andrew Wainwright - 返信
    You can usually pull the airport card out of the socket and let it dangle by the attached wires. They can be frustrating to re-attach.
    maccentric - 返信
    This seems like great advice! Any more details would be greatly appreciated
    Colleen V -
    Just walk it out slowly. The cables don’t have a lot of slack, so if you pull too hard on the card it may yank the cables out of their sockets, or worse, when it comes free.
    maccentric -
    When I did this, one antenna connection broke off and the other will not reattach for love nor money. I have not idea how to fix it. I’d try a blob of solder if my fingers were the size of matchsticks! Haha
    Andrew Aldis - 返信
  12. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 12、 1の画像 1
    • バッテリーを上部ケースに固定している次のネジを外します。
    • 5.2 mm T5 トルクネジー2本
    • 6 mm T5トルクネジー1本
    • 2.6 mm T5トルクネジー2本
  13. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 13、 1の画像 1
    • バッテリーの作業中は、6つのリチウムポリマーバッテリーセルを触ったり、握ったりしないでください。
    • ロジックボード付近の端からバッテリーを持ち上げて、上部ケースから取り出します。
  14. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 14、 2の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 14、 2の画像 2
    • ロジックボード上のソケットから電源ケーブルを引き抜いて、I/Oボードの接続を外します。
    • Airの正面端に向けて、ロジックボードの表面と並行にケーブルを引きます。
    Did it wrong to begin with by taking the complete socket away and not just the insert. Now I can’t get the socket back on the logic board contacts. Any ideas?
    John Lillywhite - 返信
    I have the same issue! Did you find a solution?
    Alexis Townsend -
    It's safer and easier to use the tip of a spudger to depress the catch located on the top of the socket. Push down and towards the connector and it will ease itself out without damage.
    jgreenb2 - 返信
  15. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 15、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 15、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 15、 3の画像 3
    • スパッジャーの先端を使って、ロジックボード上の切り欠きからアンテナケーブルを巻き戻して外します。
    I ordered a used display and the antennae wires are way too short to make it in to their respective ports (either of them). Am I missing something? Anything I should know to do a splice?
    -Aidan
    Aidan - 返信
    I did not disconnect the tiny gold terminals, they are too fragile. I just slide out the card but leave it connected to the antenna, if replacing the logic board is the aim.
    Jurgen - 返信
    They're not clicking back in when I reassemble it
    Carson Banker - 返信
  16. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 16、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 16、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 16、 3の画像 3
    • ディスプレイデータケーブルのロックに付いている黒いプラスチックのフラップの下に、スパッジャーの先端を慎重に差し込んで、ロックをソケットから上向きに出します。
    • ロックをソケットから押し出しながら、ディスプレイデータケーブルをソケットから慎重に引き抜きます。
    • ディスプレイデータケーブルを外す際に上向きに引っ張ると、ソケットがロジックボードにダメージを与えてしまう可能性があります。ご注意ください。
  17. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 17、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 17、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 17、 3の画像 3
    • スパッジャーの先端を使って、スピーカーケーブルのコネクタの下に差し込んで、ソケットからまっすぐ持ち上げます。
    • ロジックボード上の切り欠きからケーブルを慎重に通して外します。
  18. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 18、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 18、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 18、 3の画像 3
    • スパッジャーの先端もしくは指先を使って、トラックパッドのリボンケーブルZIFソケット上の固定フラップを持ち上げます。
    • ソケット自体ではなく、ヒンジの付いた固定フラップを持ち上げているか確認してください。
    • トラックパッドのリボンケーブルを、Airの正面端に向けてソケットからまっすぐ引き抜きます。
  19. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 19、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 19、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 19、 3の画像 3
    • スパッジャーの先端を使って、キーボードバックライトのリボンケーブルZIFソケット上の固定フラップを持ち上げます。
    • キーボードのバックライトリボンケーブルをソケットから引き抜きます。
  20. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 20、 1の画像 1
    • ロジックボード上のAirPort/Bluetoothカードを固定している2.9 mm T5トルクネジを1本外します。
  21. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 21、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 21、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 21、 3の画像 3
    • AirPort/Bluetoothボードの外れている側先端をわずかに持ち上げて、ロジックボード上のソケットから引き抜きます。
    • ロジックボード上のソケットにダメージを与えないように、AirPort/Bluetoothカードを持ち上げすぎないようにご注意ください。
  22. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 22、 1の画像 1
    • 上部ケースとロジックボードを固定している3.6 mm T5トルクネジを3本外します。
    • あるモデルによっては、3.1 mm T5トルクネジが使用されています。
  23. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 23、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 23、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 23、 3の画像 3
    • ヒートシンク端をロジックボードアセンブリを慎重に持ち上げて、上部ケースのポート側から引き抜いて、Air本体より取り出します。
    • ロジックボードを交換する際は、ボードのポート側ラバーガスケットの下にラバーエッジを差し込み、それからボードを押して固定します。
    There's a screw that's connecting the logic board to the casing that has to be removed before sliding the logic board out. I found that out the hard way.
    Andrea Carter - 返信
    Only 3 were in mine, where did you find another screw?
    maccentric -
    When replacing the logic board, make sure you haven’t trapped an antenna cable underneath. Easy to sort it out now, much more annoying if you only discover it after screwing everything down first!
  24. MacBook Air 11インチ Early 2015のロジックボードの交換, ロジックボード: 手順 24、 1の画像 1
    • ヒートシンクをロジックボードに固定している2.5mm T5トルクスネジを4本外します。
  25. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 25、 1の画像 1
    • 4本全てのネジを取り外した後、ヒートシンクがロジックボードに付いているように見える場合は、スパッジャーを使用してヒートシンクをCPUの面から慎重に剥がしします。
    • ロジックボードからヒートシンクを取り出します。
    • ヒートシンクを再装着する際は、新しく放熱グリスを塗布してください。今まで放熱グリスの作業を行なったことがない方向けに、簡単なガイドを用意しています。
  26. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 26、 1の画像 1
    • SSDをロジックボードに固定している2.9mm T5トルクスネジを1本外します。
  27. MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 27、 3の画像 1 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 27、 3の画像 2 MacBook Air 11インチ Early 2015のロジックボードの交換: 手順 27、 3の画像 3
    • SSDの外れている側の先端を、しっかり手で掴める程度まで持ち上げます。
    • SSDの先端を過度に持ち上げないでください。
    • ドライブをソケットからまっすぐ引き抜きます。そしてロジックボードからドライブを取り出してください。
    • SSDwp再装着する際は、固定用ネジを取り付ける前に、正しい位置に取り付けているか確認してください。
    Help pls, my 2014 MacBook Air suddenly won’t charge or turn on. After I shut it down despite trying the smc reset, disconnecting and connecting the battery and tried the smc reset but it wouldn’t budge. Tested the charger and it’s working fine but will not show any light indication when connected to my laptop and would not turn on as well.
    Olivia Ngrim - 返信
    I finally got laptop diagnosed and it was the ic chip. Got it fixed and the laptop was working, the technician also suggested I get a new battery which I did as my old one was tossed. but camera and sound stopped working completely and the new battery stopped charging too. I checked the battery health tried all troubleshooting like nvram and smc reset but nothing worked. so I took it back and he told me to manage it that way. But I decided to get a new logic board on AliExpress for 70usd used instructions above to install myself. Finally the camera was working but laptop became slow with fan running in high speed non stop. Meanwhile the sound ain’t working still so I contacted the motherboard surplier and he suggested I a new I/o audio jack board which I did. And boom sound is back but fan still works on high speed, system is still slow and battery not charging despite diagnostics showing n battery health is normal.
    Olivia Ngrim -
    So continuation of my comment above. Apparently what was causing my fan to be running on high speed was my battery. My battery was a fake one. I was duped by the seller. If I check the battery health it keeps saying normal and not charging. I decided to try a different battery and boom the fan was quite, laptop speed was back and the Mac was operating as good as new. So I decided to get a new battery and it solved all my problem.
    Olivia Ngrim -
    Hola lo necesito para la serie C02Q4HJTGFWM de una MAC BOOK AIR 11 PULGADAS 2015, es la indicada??
    Patricia Arguello Garcia - 返信
    I have provided the full story to my MacBook shutdown and won’t turn on here MacBook shut down and won’t turn on or charge repair suggestions plus tips on fan on high speed, no sound and slow Mac experience and how I got it fixed
    Olivia Ngrim - 返信
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
15 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
4人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,771 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
3 件のコメント
Thank you so much! This actually wasn't difficult at all, especially following your guide! I was able to fix my dad's computer with a replacement logic board. He's going to be super happy about this!
Robin H - 返信
I don’t see a difference between this and the guide for the Early 2014 11” MacBook Air. Is there a difference or can I replace my dead 2014 Air’s Logic Board with a 2015? That Thunderbolt 2 port would be really helpful!
vnangia - 返信
Where can one order a Logic board?
Buntu Mfaku - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 124
今までの合計 17,137
