メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Mouse G302 Disassembly
必要な工具と部品
    1. Logitech Mouse G302 Disassembly, Open the case: 手順 1、 2の画像 1 Logitech Mouse G302 Disassembly, Open the case: 手順 1、 2の画像 2
      • Turn the mouse over to access the bottom.
      • Using a scalpel, pick, or similar tool, peel off the front and rear soles (slide pads) on the bottom of the mouse. This exposes three screws.
      • Using a Phillips #0 driver, remove the three screws circled in red.
      • Use care to salvage as much of the sole adhesive as possible, in order to reuse it. If, however the adhesive is inadequate on reassemby, contact cement is a good substitute.
      • Carefully separate the two halves of the case. Light prying may be required. If you examine the second photo you can see one of the plastic retaining tabs on the front of the top half. A pick or similar tool prove helpful without marring the case.
      • Remove the three Phillips PH000 screws circled in orange; The PCB can then be removed for inspection and repair.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech Mouse G302 Disassembly, Switch replacement: 手順 2、 2の画像 1 Logitech Mouse G302 Disassembly, Switch replacement: 手順 2、 2の画像 2
      • The switch manufacturer is Omron, part number: D2FC-F-7N. The switches have three lead pins, two of which are used.
      • My experience was one switch working intermittently. In such a case, I recommend replacing both the left and right switches.
      FixBotに聞いてみる
      コメントを追加
    3. Logitech Mouse G302 Disassembly, Switch information: 手順 3、 1の画像 1
      • This may be helpful in finding the correct or compatible replacement i.e. online vendors such as AliExpress.
      • What I used as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufactured by Omron—part number: D2F-F.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Carsten Dahl Hjarup
メンバー登録日: 11/04/13
3,128 ポイント
9のガイドは作成済み
2件のガイドコメント
what is the name and type of switch number 3 / sw3
Yanuar Arifiyanto - 返信 共有
Did the job on my own mouse just tonight. The screws are actually Phillips #000, not #0 as indicated in the guide.
Michael G - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 36
過去 30 日: 99
今までの合計 7,581
