メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M125 Button Plate Replacement
必要な工具と部品
    1. Logitech M125 Button Plate Replacement, Button Plate: 手順 1、 3の画像 1 Logitech M125 Button Plate Replacement, Button Plate: 手順 1、 3の画像 2 Logitech M125 Button Plate Replacement, Button Plate: 手順 1、 3の画像 3
      • Turn the device over and remove the two 0.5mm screws near the front of the mouse by using a Phillips #0 screwdriver.
      • The black screws used in the Logitech M125 frame are all the same size and do not need special consideration for keeping them separated. Silver colored screws are used on the circuit board and have broader heads.
      • Once the screws are removed, open the mouse from the front as it pivots at the rear.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M125 Button Plate Replacement: 手順 2、 2の画像 1 Logitech M125 Button Plate Replacement: 手順 2、 2の画像 2
      • Once the mouse is opened, remove the two black 0.5mm screws located towards the back of the mouse. These are the retention screws for the mouse button plate.
      • These screws will also require the Phillips #0 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Logitech M125 Button Plate Replacement: 手順 3、 3の画像 1 Logitech M125 Button Plate Replacement: 手順 3、 3の画像 2 Logitech M125 Button Plate Replacement: 手順 3、 3の画像 3
      • There are two tabs that further secure the mouse buttons to the frame. They are located on either side of the mouse cord retracting mechanism.
      • The tighter confines of the mouse interior will be easier to navigate with metal prying tools. While plastic tools are preferred for most plastic devices, they are too large to access the left tab in the picture.
      • To dislodge the tabs, use a prying tool while pressing down on the back of the mouse. When prying, push the tab towards the outside of the mouse.
      FixBotに聞いてみる
      コメントを追加
    4. Logitech M125 Button Plate Replacement: 手順 4、 2の画像 1 Logitech M125 Button Plate Replacement: 手順 4、 2の画像 2
      • To finish removing the button plate, continue lifting the rear of the plate until the tabs have fully left their slots.
      • Once the tabs are clear, push the plate towards the front of the mouse and lift.
      FixBotに聞いてみる
      コメントを追加
    5. Logitech M125 Button Plate Replacement: 手順 5、 1の画像 1
      • The mouse button plate has now been fully removed. In order to install the replacement, follow the instructions for this guide in reverse.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Rob Myrick
メンバー登録日: 07/17/19
267 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team S1-G2, Liner Summer 2019 UW Tacoma, Team S1-G2, Liner Summer 2019人のメンバー
UWT-LINER-SU19S1G2
5 メンバー
36のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 36
今までの合計 971
