メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G733 Charging Port Replacement
必要な工具と部品
  1. Logitech G733 Charging Port Replacement, Charging Port: 手順 1、 2の画像 1 Logitech G733 Charging Port Replacement, Charging Port: 手順 1、 2の画像 2
    • Gently begin to pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases entirely.
    FixBotに聞いてみる
    コメントを追加
  2. Logitech G733 Charging Port Replacement: 手順 2、 3の画像 1 Logitech G733 Charging Port Replacement: 手順 2、 3の画像 2 Logitech G733 Charging Port Replacement: 手順 2、 3の画像 3
    • Remove the four securing the speaker housing with the T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
    • Lift the speaker housing away from the chassis, with care not to strain the connected speaker cable.
    FixBotに聞いてみる
    コメントを追加
  3. Logitech G733 Charging Port Replacement: 手順 3、 3の画像 1 Logitech G733 Charging Port Replacement: 手順 3、 3の画像 2 Logitech G733 Charging Port Replacement: 手順 3、 3の画像 3
    • Remove the screw on the bottom right-hand side of the headphone using a Phillips #00 screwdriver.
    • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the motherboard out.
    • The scroll wheel may fly out when you pop the circuit board out. If so, just put it back in by lining up the two flat surfaces of the connectors.
    FixBotに聞いてみる
    コメントを追加
  4. Logitech G733 Charging Port Replacement: 手順 4、 2の画像 1 Logitech G733 Charging Port Replacement: 手順 4、 2の画像 2
    • Once the motherboard is loose, pull the wire out of its harness.
    • The wiring harness is glued, so be careful with it. It should pull out easily.
    FixBotに聞いてみる
    コメントを追加
  5. Logitech G733 Charging Port Replacement: 手順 5、 3の画像 1 Logitech G733 Charging Port Replacement: 手順 5、 3の画像 2 Logitech G733 Charging Port Replacement: 手順 5、 3の画像 3
    • Using the soldering iron, apply heat to three pins on one side and wiggle the port free from the melted pool of solder.
    • Repeat for the opposite side.
    • This step takes a lot of skill. Be careful not to melt the circuit board with the soldering iron, and always solder in a well-ventilated area.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Antonio Jensen
メンバー登録日: 02/14/23
727 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2023 Western Carolina University, Team 1-5, Virtue Spring 2023人のメンバー
WCU-VIRTUE-S23S1G5
4 メンバー
18のガイドは作成済み
3件のガイドコメント
Where did you get the spare USB Port from?
The Red Warrior - 返信 共有
The closest match is TE Connectivity 2338792-1 USB TYPE C 3.1 CONN REV TOP MOUNT CH1.6
James Powers - 返信 共有
2338792-1 has diffrient similar casing but diffrient pin configuration and also less pins (12), should have 14 pins. Just contacted Logitech support but they didn't want to tell me the part number. If anyone knows how to get that port, please let us know.
I want it fixed - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 38
過去 30 日: 184
今までの合計 7,088
