はじめに
Follow this guide to open a Logitech G PRO Wireless mouse.
Opening the G PRO Wireless mouse requires removing the mouse feet. If you plan to reuse the mouse feet, you’ll need to apply heat to loosen the adhesive and remove the feet with minimal bending. Bent or torn mouse feet may require replacement feet.
Note that the lower case is attached to the upper case by the battery cables and input cable. Both must be disconnected before separating the lower case from the upper case.
必要な工具と部品
Shift the power switch down to turn off your mouse (when the PRO Wireless label is oriented right-side up).
Heat an iOpener and apply it to the upper mouse foot for one minute.
Insert the flat end of a spudger under the upper mouse foot.
Slide the spudger under the length of the upper mouse foot to cut through the adhesive and detach it from the mouse.
Insert the flat end of a spudger under the left lower mouse foot.
Use a Phillips screwdriver to remove the seven 4.4 mm-long screws securing the lower case.
Lift the bottom end of the lower case about 1 cm away from the upper case.
Pull the lower case down about 0.5 cm to detach the lower case from the upper case.
Swing the lower case left to right away from the upper case.
Place the lower case on your work surface.
Lean the upper case against a sturdy object (such as a box) to prevent straining the cables.
この手順で使用する道具:Tweezers$4.99
Use a pair of blunt tweezers to pull the battery connector straight out of its slot.
Use the pointed end of a spudger or your fingernail to flip up the small, hinged locking flap on the input cable ZIF connector.
5 の人々がこのガイドを完成させました。
3 件のコメント
Any help on getting the scroll wheel fixed? Looks like eventually all G Pro have an issue with scrolling both directions anytime you touch the scroll wheel, or when scrolling down, it can actually scroll up, does cleaning the wheel help with this? This doesn't show how to get the wheel out.
For anyone looking how to clean the scroll wheel - https://www.youtube.com/watch?v=P2OiLJBI...
you have to remove the battery held by the tab with the screw, unscrew 2 screws for each of the buttons and then you can access the scroll wheel daughter board.
