この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
必要な工具と部品
To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
Pull the top piece upwards and away from the bottom to remove.
Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (はんだ付けとはんだ除去の作業ガイド).
Desolder each pin using the iFixit Soldering Guide (はんだ付けとはんだ除去の作業ガイド). Gently remove functional component for replacement.
ある他の人がこのガイドを完成しました。
