メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Linksys WAP 11 Network Port Replacement
必要な工具と部品
    1. Linksys WAP 11 Network Port Replacement, Outer Case: 手順 1、 1の画像 1
      • Disconnect the power cables and ethernet from the device.
      • Unscrew the external plastic antennas. There is one antenna on each side of the device.
      FixBotに聞いてみる
      コメントを追加
    2. Linksys WAP 11 Network Port Replacement: 手順 2、 3の画像 1 Linksys WAP 11 Network Port Replacement: 手順 2、 3の画像 2 Linksys WAP 11 Network Port Replacement: 手順 2、 3の画像 3
      この手順で使用する道具:
      • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
      • Use the tweezers to remove the two rubber boots from the front two legs. Insert the tweezers in the hole of the boot and pull outwards.
      • This will reveal two small Phillips-head screws. Remove them.
      • Keep these two screws together.
      FixBotに聞いてみる
      コメントを追加
    3. Linksys WAP 11 Network Port Replacement: 手順 3、 2の画像 1 Linksys WAP 11 Network Port Replacement: 手順 3、 2の画像 2
      • Using two hands, pull on the top and bottom sections to separate the blue and the black pieces.
      • This requires significant amount of force.
      • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
      FixBotに聞いてみる
      コメントを追加
    4. Linksys WAP 11 Network Port Replacement: 手順 4、 1の画像 1
      • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
      • When removing the base, do not damage the wires that are attached to the device.
      FixBotに聞いてみる
      コメントを追加
    5. Linksys WAP 11 Network Port Replacement: 手順 5、 1の画像 1
      • This is what the device looks like when it is fully opened.
      FixBotに聞いてみる
      コメントを追加
    1. Linksys WAP 11 Network Port Replacement, Motherboard: 手順 6、 2の画像 1 Linksys WAP 11 Network Port Replacement, Motherboard: 手順 6、 2の画像 2
      • At this point, remove the antenna leads as well.
      • Proceed to remove the remaining three phillips screws fastening the motherboard to the case.
      • Once the screws are removed, your motherboard will separate from the housing.
      • Keep these three screws together and separate from the outer case screws.
      FixBotに聞いてみる
      コメントを追加
    1. Linksys WAP 11 Network Port Replacement, Network Port: 手順 7、 1の画像 1
      • Ifixit soldering guide Soldering and desoldering have the potential for harm, always wear proper eye protection and other personal protective equipment while performing either action!
      • Turn the main circuit board around and using a soldering iron and desoldering wick desolder the 12 pins that secure the port to the main board.
      FixBotに聞いてみる
      コメントを追加
    2. Linksys WAP 11 Network Port Replacement: 手順 8、 2の画像 1 Linksys WAP 11 Network Port Replacement: 手順 8、 2の画像 2
      • Using a pair of needle-nose pliers, squeeze the two black plastic clips that secure the network port to the board. Squeeze and push down at the same time to push the network board out of place and remove it from the board.
      • To replace the network port, line up the black plastic clips and pop a new network port into the holes. Reassemble in reverse order.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
8人の作成者と共同で作成されました。
Joe M
メンバー登録日: 10/12/11
159 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-17, Regan Fall 2011 Cal Poly, Team 3-17, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S3G17
5 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 34
今までの合計 1,219
