メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lexibook Junior Tablet Motherboard Replacement
必要な工具と部品
    1. Lexibook Junior Tablet Motherboard Replacement, Battery: 手順 1、 1の画像 1
      • Make sure your device is powered off before replacement to prevent electric shock.
      • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
      • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
      FixBotに聞いてみる
      コメントを追加
    2. Lexibook Junior Tablet Motherboard Replacement: 手順 2、 1の画像 1
      • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
      • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
      • Use the plastic opening tool to gently pry open the back panel of the tablet.
      FixBotに聞いてみる
      コメントを追加
    3. Lexibook Junior Tablet Motherboard Replacement: 手順 3、 1の画像 1
      • Use the nylon spudger to gently pry under the battery to remove it.
      • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
      FixBotに聞いてみる
      コメントを追加
    4. Lexibook Junior Tablet Motherboard Replacement: 手順 4、 1の画像 1
      • Use a soldering iron to remove the battery from the motherboard safely.
      • For advice on how to solder, check out iFixit's Soldering Guide.
      FixBotに聞いてみる
      コメントを追加
    1. Lexibook Junior Tablet Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Lexibook Junior Tablet Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
      • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
      • Slowly pull the ribbon wire out of the switch to free it.
      FixBotに聞いてみる
      コメントを追加
    2. Lexibook Junior Tablet Motherboard Replacement: 手順 6、 1の画像 1
      • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
      • Carefully pull the ribbon wire out of the switch
      FixBotに聞いてみる
      コメントを追加
    3. Lexibook Junior Tablet Motherboard Replacement: 手順 7、 3の画像 1 Lexibook Junior Tablet Motherboard Replacement: 手順 7、 3の画像 2 Lexibook Junior Tablet Motherboard Replacement: 手順 7、 3の画像 3
      • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
      FixBotに聞いてみる
      コメントを追加
    4. Lexibook Junior Tablet Motherboard Replacement: 手順 8、 2の画像 1 Lexibook Junior Tablet Motherboard Replacement: 手順 8、 2の画像 2
      • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
      FixBotに聞いてみる
      コメントを追加
    5. Lexibook Junior Tablet Motherboard Replacement: 手順 9、 1の画像 1
      • Solder off connections from the wire connecting the motherboard to the speaker.
      • For how to solder, check out iFixit's Soldering Guide.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Rachel Klesius
メンバー登録日: 09/19/16
645 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 17-3, Blackwell Fall 2016 USF Tampa, Team 17-3, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S17G3
4 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 34
今までの合計 633
