メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LexiBook Tablet One MotherBoard Replacement
必要な工具と部品
  1. LexiBook Tablet One MotherBoard Replacement, Battery: 手順 1、 3の画像 1 LexiBook Tablet One MotherBoard Replacement, Battery: 手順 1、 3の画像 2 LexiBook Tablet One MotherBoard Replacement, Battery: 手順 1、 3の画像 3
    • First the case must be opened. Insert the blue plastic opening tool where the two casings meet. Pry up until you hear a clip pop and then carefully move around the device. Do this until the front and back casing are completely separate from one another.
    • You will again need to be careful opening the device in order to avoid damaging the speaker, or worse, the motherboard.
    • The clips holding the case together are roughly 1.5 in. apart.
    FixBotに聞いてみる
    コメントを追加
  2. LexiBook Tablet One MotherBoard Replacement: 手順 2、 2の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 2、 2の画像 2
    • Carefully remove the speaker by inserting the spudger between the case and the speaker. Pry upwards until the speaker comes out. Set the speaker to the side.
    • Be careful with the speaker wires. The wires can easily detach from both the speaker and the board.
    FixBotに聞いてみる
    コメントを追加
  3. LexiBook Tablet One MotherBoard Replacement: 手順 3、 1の画像 1
    • Use the spudger to repeatedly gouge between the battery and LCD. Work around the battery until it breaks free.
    • It may feel as though you are pushing extremely hard. This is normal as the adhesive is quite strong. As long as you don't tip the tool you use and puncture the battery / LCD it will be fine.
    FixBotに聞いてみる
    コメントを追加
  4. LexiBook Tablet One MotherBoard Replacement: 手順 4、 2の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 4、 2の画像 2
    • The tape around the battery's circuit board is extremely thorough. There are 2 pieces of tape, on folded over the side and another wrapped around the circuit board. Simply peel both off.
    FixBotに聞いてみる
    コメントを追加
  5. LexiBook Tablet One MotherBoard Replacement: 手順 5、 2の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 5、 2の画像 2
    • Now that the battery is pry'd free and the tape is removed, the wires should be able to move freely. Give yourself as much room as you need, and solder off the connections on the motherboard.
    • How to Solder is iFixit's official guide to use a soldering gun.
    FixBotに聞いてみる
    コメントを追加
  6. LexiBook Tablet One MotherBoard Replacement, MotherBoard: 手順 6、 1の画像 1
    • Remove the tape from these ribbon cables and their clips.
    • Wires from the speaker may be under the tape and remain stuck to it, care not to disconnect them from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. LexiBook Tablet One MotherBoard Replacement: 手順 7、 2の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 7、 2の画像 2
    • Remove the LCD and Digitizer ribbon cables from the motherboard by holding the clips open and pulling the ribbons out.
    FixBotに聞いてみる
    コメントを追加
  8. LexiBook Tablet One MotherBoard Replacement: 手順 8、 2の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 8、 2の画像 2
    • Remove the Camera Ribbon Cable, by holding the clip open and pulling the camera out.
    FixBotに聞いてみる
    コメントを追加
  9. LexiBook Tablet One MotherBoard Replacement: 手順 9、 2の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 9、 2の画像 2
    • Using a screwdriver, unscrew the 3 screws which hold the motherboard on the case.
    • A 3/16 in. Phillips head screw driver will fit the screw heads easily.
    • These are the only three screws in the device and are all the same size.
    FixBotに聞いてみる
    コメントを追加
  10. LexiBook Tablet One MotherBoard Replacement: 手順 10、 3の画像 1 LexiBook Tablet One MotherBoard Replacement: 手順 10、 3の画像 2 LexiBook Tablet One MotherBoard Replacement: 手順 10、 3の画像 3
    • You must now use a soldering kit to remove the connections to the motherboard.
    • The battery wires. (If you had not finished this in an earlier step).
    • The Speaker Wires.
    • The Ground.
    • The LCD wires.
    • Finally, the microphone, which lies under the board.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Daniel
メンバー登録日: 03/11/15
249 ポイント
1ガイドが承認済み
チーム
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G5
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 48
今までの合計 831
