はじめに
Also known as a chip card or an integrated circuit card (ICC or IC card), the smart card is a physical authorization device shaped like a credit card, and is used to gain access of another device. Smart cards can provide strong security for things like identity, authentication, financial records, etc. The smartcard reader houses the smart card, and can read or write the information on a smart card.
If you find that your device is not properly reading or writing the information on a smart card, it may be time to replace it. Follow these instructions to replace the smartcard reader in the Lenovo ThinkPad T450 laptop.
必要な工具と部品
Using your hands, slide the two locking tabs away from each other to release the battery.
Slide the battery up and out of the device.
Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
Using the JIS #00 screwdriver, unscrew the four screws securing the fan and heatsink assembly to the motherboard.
Use the plastic opening tool to remove the black piece of tape holding the cables together.
Using the plastic opening tool, disconnect the CMOS battery from the motherboard.
Use the JIS #00 screwdriver to remove two 2.8 mm screws securing the display cable bracket to the motherboard.
Remove the display cable bracket from the device.
Using the JIS #00 screwdriver, remove the four 2.8 mm screws securing the smartcard reader and bracket to the device.
ある他の人がこのガイドを完成しました。
