はじめに
The motherboard of a laptop is the component that connects all of the other components together. It is the main PCB or primary printed circuit board that exists in many sizes and configurations depending on the laptop. It could also be considered the backbone of the laptop.
If the motherboard of your Lenovo ThinkPad T480 crashes you may need to replace it. Signs that it needs to be replaced include physical damage, freezing or glitching, the “blue screen of death”, overheating, slowing down, blank screen, and not recognizing hardware.
Prior to beginning this repair, be sure to disable the internal battery, power off the device, and unplug the laptop from any external power source.
必要な工具と部品
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the Phillips #1 screwdriver, remove two 4.8 mm screws from the right speaker.
Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
ある他の人がこのガイドを完成しました。
