メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo ThinkPad P50 Display Replacement
必要な工具と部品
  1. Lenovo ThinkPad P50 Display Replacement, Battery: 手順 1、 2の画像 1 Lenovo ThinkPad P50 Display Replacement, Battery: 手順 1、 2の画像 2
    • Slide the battery latch to the left to unlock it and remove the battery.
    FixBotに聞いてみる
    コメントを追加
  2. Lenovo ThinkPad P50 Display Replacement, Bottom case screws: 手順 2、 1の画像 1
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
    FixBotに聞いてみる
    コメントを追加
  3. Lenovo ThinkPad P50 Display Replacement, Bottom case: 手順 3、 2の画像 1 Lenovo ThinkPad P50 Display Replacement, Bottom case: 手順 3、 2の画像 2
    • Lift the lower case up and off of the chassis.
    FixBotに聞いてみる
    コメントを追加
  4. Lenovo ThinkPad P50 Display Replacement, Display: 手順 4、 2の画像 1 Lenovo ThinkPad P50 Display Replacement, Display: 手順 4、 2の画像 2
    • Use an iFixit opening pick to carefully remove the plastic bezel from the front of the display.
    • There are clips beneath the trim that need to be carefully detached.
    • Avoid using metal tools, as they can damage the plastic components.
    FixBotに聞いてみる
    コメントを追加
  5. Lenovo ThinkPad P50 Display Replacement: 手順 5、 1の画像 1
    • Remove the four 2.5 mm screws located along the corners with a Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  6. Lenovo ThinkPad P50 Display Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad P50 Display Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad P50 Display Replacement: 手順 6、 3の画像 3
    • Carefully tilt the screen forward and lay it face down on the keyboard, making sure not to strain or damage the cable still attached to it.
    • Display (sometimes called eDP cables in laptops) and camera cable connectors often have a small metal buckle running around the socket, locking them in place. The connectors are typically wide and may have tape attached to the buckle.
    • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Hold the buckle and cable together and gently pull the connector straight out of its socket.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Sara Richardson
メンバー登録日: 03/21/25
609 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 3-1, Botvin Spring 2025 UMass Dartmouth, Team 3-1, Botvin Spring 2025人のメンバー
UMASSD-BOTVIN-S25S3G1
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 106
今までの合計 615
