はじめに
充電レールが破損すると、Nintendo Switch本体に直接接続できなくなったり、Joy-Conの充電ができなくなったりします。このガイドでは、左側Joy-Conコントローラーの充電レールを交換する方法を説明します。
このガイドを使用する前に、充電レールのピンが曲がっていないか確認してください。可能であればJoy-Conが外部ソースから充電できるテストするか、問題が実際にNintendo Switch本体のセンサーレールにあるかどうかを確認してください。
Nintendo Switchのセンサーレールに問題がある場合は、 Nintendo Switch 左側ジョイコン センサーレールの交換を参照してください。
必要な工具と部品
30 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
14 件のコメント
I did this and still doesn’t work. I also changed the rail on the console side too. Very carefully of course. Any ideas?
Hey Luis,
Can you give me more detail on the problem? Like is the Joy-Con not being detected when it’s plugged in or is it not charging. If possible, can you test the console rail with a working Joy-Con?
If the Joy-Con is not charging, it could also be a battery problem. If you are comfortable with it, I would suggest swapping out the battery with a working one from the other Joy-Con to see if it solves the problem. You should probably attempt this after double-checking the connections for potential tears or if the connectors are too loose in the sockets.
Hi, I need help. My left Joy-Con is not charging because of the ZIF connector for the charging rail ribbon has been detached and I have lost it. Is there a way to fix this problem?
Honestly, I would recommend replacing the entire Motherboard, unless you can find a trusted repair shop to solder it on.
I damaged the ZIF connector for the battery on my Switch. It works with some pressure and perfect alignment, but I've had issues ever since I damaged it during repairs :/
I'm going to swap it with a functional motherboard, I would advise you do the same.
Hello need a little help. the ribbon cable will not stay connected. and it will not charger. Any thing will help.
