メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG VX6100 Main Display Replacement
必要な工具と部品
  1. LG VX6100 Main Display Replacement, Battery: 手順 1、 1の画像 1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    FixBotに聞いてみる
    コメントを追加
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
    FixBotに聞いてみる
    コメントを追加
  2. LG VX6100 Main Display Replacement: 手順 3、 1の画像 1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    FixBotに聞いてみる
    コメントを追加
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
    FixBotに聞いてみる
    コメントを追加
  3. LG VX6100 Main Display Replacement, Front Case: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Remove the four grey plugs using either tweezers or a push pin.
    FixBotに聞いてみる
    コメントを追加
  4. LG VX6100 Main Display Replacement: 手順 6、 1の画像 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
    FixBotに聞いてみる
    コメントを追加
  5. LG VX6100 Main Display Replacement: 手順 7、 1の画像 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
    FixBotに聞いてみる
    コメントを追加
  6. LG VX6100 Main Display Replacement: 手順 8、 1の画像 1
    • The case can now be removed and the interior of the front is accessible.
    FixBotに聞いてみる
    コメントを追加
  7. LG VX6100 Main Display Replacement, Main Display: 手順 9、 2の画像 1 LG VX6100 Main Display Replacement, Main Display: 手順 9、 2の画像 2
    • Locate the solder on the side of the metal plate on the top half of the phone.
    • Place a piece of solder wick on top of the solder.
    • To desolder the connection, very carefully place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • The soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
    FixBotに聞いてみる
    コメントを追加
  8. LG VX6100 Main Display Replacement: 手順 10、 1の画像 1
    • After the solder has been removed, pry off the camera assembly connection shield with the plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
  9. LG VX6100 Main Display Replacement: 手順 11、 2の画像 1 LG VX6100 Main Display Replacement: 手順 11、 2の画像 2
    • Remove the main display by lifting up the extruded white edge with your fingernail.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Ryan Bishop
メンバー登録日: 04/17/12
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S12G39
3 メンバー
32のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 36
今までの合計 1,524
