メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Refrigerator Compressor Run Capacitor Replacement
必要な工具と部品
  1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    FixBotに聞いてみる
    コメントを追加
  2. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
    FixBotに聞いてみる
    コメントを追加
  3. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: 手順 3、 3の画像 1 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: 手順 3、 3の画像 2 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: 手順 3、 3の画像 3
    • Tilt the top edge of the cover toward you and lift it off.
    FixBotに聞いてみる
    コメントを追加
  4. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: 手順 4、 3の画像 1 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: 手順 4、 3の画像 2 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: 手順 4、 3の画像 3
    • Pull the left edge of the capacitor toward you to unclip it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • For information on capacitor safety, click here.
    FixBotに聞いてみる
    コメントを追加
  5. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: 手順 5、 3の画像 1 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: 手順 5、 3の画像 2 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: 手順 5、 3の画像 3
    • Pull the connector straight off the capacitor to disconnect it.
    • Remove the capacitor.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Bill Gilbert
メンバー登録日: 06/30/22
40,146 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
32,272のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 118
今までの合計 3,328
