メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Grace Screen Replacement
必要な工具と部品
  1. LG Grace Screen Replacement, Phone Assembly: 手順 1、 1の画像 1
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
    FixBotに聞いてみる
    コメントを追加
  2. LG Grace Screen Replacement: 手順 2、 1の画像 1
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
    FixBotに聞いてみる
    コメントを追加
  3. LG Grace Screen Replacement: 手順 3、 2の画像 1 LG Grace Screen Replacement: 手順 3、 2の画像 2
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
    FixBotに聞いてみる
    コメントを追加
  4. LG Grace Screen Replacement: 手順 4、 2の画像 1 LG Grace Screen Replacement: 手順 4、 2の画像 2
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
    FixBotに聞いてみる
    コメントを追加
  5. LG Grace Screen Replacement, Rear Camera: 手順 5、 1の画像 1
    • Locate the pin connection for the camera, noted by red box in the guide photo.
    • Gently lift the camera up while pulling away from connection; it should detach with minimal effort.
    FixBotに聞いてみる
    コメントを追加
  6. LG Grace Screen Replacement, Motherboard: 手順 6、 1の画像 1
    • Next we remove the front speaker from the motherboard, with the goal of removing all connections that hold the board in place.
    • The location of the speaker is highlighted in the guide photo.
    • Just like with the camera, gently pull the ribbon wire away from the connector and it should release easily.
    FixBotに聞いてみる
    コメントを追加
  7. LG Grace Screen Replacement: 手順 7、 1の画像 1
    • There is also a ribbon cable connected to the board by the charging port, as highlighted in the photo.
    • Pull it away in the same fashion as the others, and now the motherboard should be free.
    FixBotに聞いてみる
    コメントを追加
  8. LG Grace Screen Replacement: 手順 8、 1の画像 1
    • From here, you should be able to gently pull the motherboard away from the screen assembly and remove it. I recommend grabbing the edge by the port and lifting with one hand while holding the phone down with the other.
    FixBotに聞いてみる
    コメントを追加
  9. LG Grace Screen Replacement, Screen: 手順 9、 2の画像 1 LG Grace Screen Replacement, Screen: 手順 9、 2の画像 2
    • Now we remove the audio jack. Place something long and thin in the jack and pry up to remove it from it's seating.
    • Use the Jimmy to slide under the connection to the screen assembly and pry it up and away.
    FixBotに聞いてみる
    コメントを追加
  10. LG Grace Screen Replacement: 手順 10、 1の画像 1
    • Now we remove the side rocker buttons. To do this we place the jimmy along the inside of the buttons and pry up and away gently.
    • This is risky for the buttons, be gentle and if they appear to be bending, stop and try another angle.
    FixBotに聞いてみる
    コメントを追加
  11. LG Grace Screen Replacement: 手順 11、 1の画像 1
    • Next we will remove the front speaker.
    • Place a jimmy underneath the small connection to the screen assembly, and pry away.
    • When it's disconnected, remove from the assembly.
    FixBotに聞いてみる
    コメントを追加
  12. LG Grace Screen Replacement: 手順 12、 1の画像 1
    • Finally we remove the CMOS battery. After this the screen assembly shouldn't have any components left on it.
    • Use the jimmy or other prying tool to pry the battery up from the connection; it may be difficult but you should be able to find the right angle of approach. The jimmy is thin enough that I found it more effective.
    • The new screen assembly will have identical places to put all of the components you removed.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Dylan Kent
メンバー登録日: 09/09/23
679 ポイント
6のガイドは作成済み
チーム
University of New Orleans, Team 4-3, McDonald Fall 2023 University of New Orleans, Team 4-3, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S4G3
3 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 28
今までの合計 314
