はじめに
Use this guide to replace the pump assembly in your LG front load washing machine.
The pump assembly drains the tub and expels wastewater out of the washer. It includes the drain pump and drain filter housing.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
必要な工具と部品
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Pull the detergent drawer away from the chassis as far as it will go.
Remove the screw(s) securing the control panel to the top edge of the chassis.
Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
Remove the control panel, making sure to thread any cables through the chassis.
Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
Pull the ring away from the chassis to separate it from the boot.
Use your hand to completely pull the ring off the boot.
Insert one end of the ring into its groove along the boot's perimeter.
Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
Open the filter panel at the bottom of the front panel.
Unclip the filter panel.
Place a bowl next to the machine.
Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
Remove the plug at the end of the drain filter hose to release excess water into the bowl.
Pull the door latch through its slot in the chassis and let it hang on its wire.
Lift the front panel upward to separate it from its clips on the bottom of the chassis.
Pull the front panel away from the chassis to completely separate the front panel.
Push the drain hose through its hole in the chassis until it's completely inside the device.
Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
Lift the pump assembly out of its location in the frame to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
4 の人々がこのガイドを完成させました。
2件のガイドコメント
Wow, that's intense. I wonder if I can just prop it up and get to that pump from the bottom? I don't have a jack stand or anything but I saw someone lean it back into a metal step stool.
Doyle Stadt - 返信 共有
