はじめに
Use this guide to replace the door latch in your LG front load washing machine.
The door latch is electronically actuated. If your washer's door won't latch, you may need to replace this part.
This guide will work for most LG front-load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
必要な工具と部品
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
Pull the ring away from the chassis to separate it from the boot.
Use your hand to completely pull the ring off the boot.
Insert one end of the ring into its groove along the boot's perimeter.
Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
Reach between the boot and the chassis to grip the door latch.
Pull the door latch out of its slot in the chassis to expose it.
Disconnect the cable harness from the door latch.
Remove the door latch.
Repair didn’t go as planned? Ask our Answers community for help.
3 の人々がこのガイドを完成させました。
