はじめに
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to remove the battery inside the device.
必要な工具と部品
Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
ある他の人がこのガイドを完成しました。
