メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kindle Paperwhite 2nd Generation Charging Port Replacement
必要な工具と部品
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: 手順 1、 2の画像 1 Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: 手順 1、 2の画像 2
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
      • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
      FixBotに聞いてみる
      コメントを追加
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 2、 2の画像 1 Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 2、 2の画像 2
      • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      FixBotに聞いてみる
      コメントを追加
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 3、 1の画像 1
      • Carefully remove the mid-frame from the back cover.
      FixBotに聞いてみる
      コメントを追加
    4. Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 4、 2の画像 1 Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 4、 2の画像 2
      • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
      FixBotに聞いてみる
      コメントを追加
    5. Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 5、 1の画像 1
      • Carefully lift the battery and remove it from the device.
      FixBotに聞いてみる
      コメントを追加
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: 手順 6、 2の画像 1 Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: 手順 6、 2の画像 2
      • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
      • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
      FixBotに聞いてみる
      コメントを追加
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 7、 2の画像 1 Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 7、 2の画像 2
      • Gently disconnect the zif connectors.
      • Some of these connectors are very thin and fragile, handle with care!
      FixBotに聞いてみる
      コメントを追加
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 8、 3の画像 1 Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 8、 3の画像 2 Kindle Paperwhite 2nd Generation Charging Port Replacement: 手順 8、 3の画像 3
      • Gently remove the motherboard.
      FixBotに聞いてみる
      コメントを追加
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Charging Port: 手順 9、 1の画像 1
      • The charging port is integrated in to the device motherboard.
      • From here, to fix a faulty port, either replace the entire motherboard, or carefully desolder the old port and solder a new one on in its place.
      • Check out the soldering guide for help.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tyler Davis
メンバー登録日: 09/15/16
2,007 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S11G2
4 メンバー
25のガイドは作成済み
10件のガイドコメント
How to replace the USB port; replace the motherboard. Kind of a lame fix if you ask me. Whatever happened to soldering a new port on?
Sam Hardeman - 返信 共有
I have not done the fix yet but plan to replace the USB which appears to be a USB - micro B USB 2.0 Receptacle Connector 5 Position Surface Mount available at DigiKey. Is there any reason not to attempt this? I have microscope and soldering station. If not, where do you get the motherboard and how much is it?
Bill Smith - 返信 共有
Any updates? Did you run into any issues?
theend12212012 - 返信 共有
Démontage facile effectivement, mais les cinq microsoudures sur la carte mère sont impossibles à faire avec un simple fer à souder ! Il faut utiliser du matériel pour CMS (composant à montage en surface)…
Ceci dit mon problème vient effectivement de ces microsoudures. En appuyant simplement sur ces contacts mon Kindle s’est remis en marche ! Vive le travail mal fait à la construction…
telerando - 返信 共有
Getting the Kindle open and getting to the charging port was quite ‘easy’. In step 1 the top is stuck on with something like sticky back tape and the top can be gently pulled away from the tape.
Having got to the port I can not figure out how to replace it. This part does not seem to be easy, unless Step 9 is explained in much more detail. The contacts for the port seem to be incredibly small and I can’t figure out how they’re connected, or what part I need to order to replace the port.
Richard Garside - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 250
今までの合計 32,347
