メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Kindle 3 Battery Replacement
必要な工具と部品
  1. Kindle 3 Battery Replacement, Remove Rear Cover: 手順 1、 3の画像 1 Kindle 3 Battery Replacement, Remove Rear Cover: 手順 1、 3の画像 2 Kindle 3 Battery Replacement, Remove Rear Cover: 手順 1、 3の画像 3
    • Turn the device upside-down and insert a pry tool between the two case pieces.
    • On the left side just below the buttons there's a delicate ribbon cable that's part of the screen assembly and may be severed by a pry tool. (This is shown in the third photo, it's where the tool is pointing.) Regardless of where you start, stay clear of this area!
    • If you are having trouble getting an initial gap to pry from, run the flat edge of the pry tool along the front-to-back plate seam until it slips into a gap. You can also flex the device slightly and work a tool into one of the lower corners, which have a lot of empty space behind them rather than fragile components.
    • Looking at the back face, another safe place to start is on the right side just below the page turn buttons. (Note the green arrow in the board photo, which is rotated 90 degrees counter-clockwise.) The tool goes between the lower button and the hinge cover slot. If there isn't a slot there, you're on the wrong side!
    • Do not attempt to pry directly on the page turning buttons.
    • Work the pry tool around the edge of the case, releasing the 18 clips. Don't insert your tool too far, or you may damage components near the edges of the device. The clips are all in the outer edge of the backplate anyway. Note that the clip above the power switch is bigger and stronger than the rest.
    • Pull the rear cover off. The remaining two clips near the center of the back are surprisingly strong.
    • When reinstalling the back cover, slide the bottom edge into place first, and then press up the sides and along the top until all the clips snap into place.
    Ah, I put it on in the wrong order, then figured out that starting at the bottom works best. I did the bottom, top and corners and then the sides, because I already had the top done.
    kwood - 返信
    BE VERY CAREFUL HERE!! 15mm below the "next page" button was directly where the flex cable was. And it is an extremely fragile cable, even for flex cables. Which means I, of course, tore right through it without knowing until I got the cover off. So don't do that. Start 15mm above the lower corner, if anything, or start on the opposite side. Starting on the side with a single-point-of-failure is a really risky choice. The opposite side has basically nothing up against the edge, so you're free to poke it.
    The other thing that isn't stated here is that the flex cable is inherently tied into the screen. Which means that if you, like me, damage that cable, the entire screen now broken and needs replacing. And if you, like me, was just trying to replace the battery or the motherboard, now it just makes sense to replace the entire device, both environmentally and financially. Whomp whomp.
    bhurwitz - 返信
    As is, the guide sets you up SPECIFICALLY to DAMAGE THE SCREEN by prying into its very delicate ribbon cable.
    A Kenny - 返信
    Apart from the buttons, are there any other specific places where we shouldn't pry, because it would damage something?
    okojoijohoij - 返信
    There are clips a several centimeters from the edge of the Kindle across from the page-turning buttons. Undoing these clips was the most difficult part of opening the back of the Kindle. Be careful and take your time here.
    It's a good idea to start on at the left page-turning button to help minimize risk of damage to the flex cable.
    John Thoreson - 返信
    I've submitted an edit clearing up where to start the pry tool. Please folks, if you encounter something like this don't hesitate to remove bad information! With the contradictory instructions here I ended up starting on the left and piercing the cable like so many before me, which is very frustrating.
    Jakob C - 返信
    Die Anleitung sollte in diesem Punkt wirklich überarbeitet werden. Das ist die absolut gefährlichste Stelle, das Gerät zu öffnen. So habe ich das Flex-Kabel eines funktionierenden Displays zerstört. Ich schreibe dies auf Deutsch und bitte darum, die englischen Erläuterungen zu lesen, wo man besser öffnet.
    Kajetan Hinner - 返信
    I submitted an edit adding that the corners are another good place to start (it's how I just opened mine with no trouble) and moved the ribbon cable warning up to make sure people see it.
    Neal Sofge - 返信
    Regarding two last (central) clips, it helps to know they both are facing the same way and after releasing the outer clips you can slide the back cover slightly towards the top of device to release them.
    Konrad Grzegorzewicz - 返信
  2. Kindle 3 Battery Replacement, Release Battery: 手順 2、 1の画像 1
    • Unscrew the two silver 4 mm Phillips screws securing the battery connector.
    • Set the screws aside in a safe place -- there are exposed components and it's easy for them to short-circuit something.
  3. Kindle 3 Battery Replacement, Replace Battery: 手順 3、 3の画像 1 Kindle 3 Battery Replacement, Replace Battery: 手順 3、 3の画像 2 Kindle 3 Battery Replacement, Replace Battery: 手順 3、 3の画像 3
    • Lift battery out of housing starting at the end that was secured by the screws.
    • Watch out for the odd-shaped silver washers beneath the battery connector (see second photo); they are necessary for proper mating of the electrical contacts when the screws are re-tightened.
    • When reinstalling the battery, make sure the washers are in place. Holding the battery at an angle (see first photo), insert the two retaining tabs on the bottom of the battery into the slots in the case. Then rotate the battery into place and screw down the connector.
    Remove the washers and place them with the screws, don’t leave them on the board, you’ll be removing it later and you don’t want to have them slide off.
    domarius - 返信
    The washer came loose. Will it be ok?
    Sunrise Sunset - 返信
    I lost one of the washers. What do they do and where can I buy one? What’s the specific name for it?
    Elena - 返信
    They hold the battery flat. Without it pulls the battery into a curve. I have plenty of spare parts, including motherboards, both Wi-Fi and 3G. I’m in the UK
    Chris Halliwell -
    This helped me change my Kindle Keyboards battery easily. Thank you!
    Ann Thornton (AnnDroidGirl) - 返信
    In my case, battery died. I replaced it with a spare pouch li-ion I had - the thing is, this battery communicates it's status through I2C, so I had to crank it open to separate the PCB from the actual battery. After doing so, I only had to solder the new battery between + and -, close up and it worked like a charm 😀
    Esteban Zapirain - 返信
    Changed the battery as per instructions - all seemed good. Noticed though that one of the washers is missing. Don't know if that was me when changing the battery. Can replacements be sourced anywhere?
    Brian - 返信
終わりに
To reassemble your device, follow these instructions in reverse order, paying attention to the reassembly notes in the individual steps.
97 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Allison Monahan
メンバー登録日: 09/08/14
3,028 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team 1-5, Bruce Fall 2014 CSU Fullerton, Team 1-5, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S1G5
4 メンバー
15のガイドは作成済み
23 件のコメント
Hi Allison Monahan,
thank you very much for yor help! By using your guide I made my nearly 6 years old Kindle Keyboard fixed - great!
Stefan Schiche - 返信
I went to mpfproducts.com and ordered my new battery which came in today. I’ve changed out the battery and my Kindle 3 is now charging. YAHOO!!!
Ruth Kuykendall - 返信
Where did you get the battery? I couldn’t find it on Amazon. Do you have a model number for the battery? Thanks.
sand1k -
The old Amazon link has been removed. There’s now a link at the top of this guide to an eBay vendor that stocks the battery. Good luck!
Jeff Suovanen -
Thanks, Allison and IFIXIT!!! God, I love this site. Cheers, Tom
tombeanhall - 返信
My Kindle won’t turn on, but the on/off switch glows. It has been working, somewhat. If I tried to turn it off, it would reboot, so I just let it go to sleep on its own. Does the battery need replacing?
Judi Johnson - 返信
My 10-year old kindle is now like-new. Bought my replacement battery (with tools included) at:
https://www.mpfproducts.com/gp-s10-34639...
aseisman - 返信
The toughest part was prying off the back. Be careful but forceful, those who are attempting this! Thank you for the guide and the part, iFixit!
Sean Williams - 返信
Putting the back on was a bit tricky. The secret seems to be to do the ends and corners first. Then it snaps on easily because the forward and back buttons are somewhat more flexible than the ends and the corners.
kwood - 返信
Terrifically useful - rescued my old Kindle. Thank you Allison!
Mark - 返信
This is great! Thank you for the guide!
Giorgi - 返信
Hi
I lost the 2 silver washers, what do i do now?
selvan govender - 返信
Thanks, my 2010 Kindle 3 is as good as new :D
Vojtěch Míček - 返信
My Kindle 3 was 12 years old and the battery died. Given my very limited skills in working on devices (that is, taking them apart etc), I was happy to have found this guide. With some difficulty opening it, I managed to replace the battery. And, thanks to the tip about the silver washers I knew what to do with them when I saw them on my desk after I had closed the kindle and it was dead. So, I opened it again, put the silver washers in place, and, voila, hopefully I have another 12 years with this. I prefer the older Kindles, with no backlight. So this guide was immensely helpful. tnx
Dana Kenneth Lewis - 返信
Great tutorial! Went smoothly and now our Kindle is ready for more years of trouble free service and we don’t have to buy a new one! Thanks, Allison and I Fix It for helping us with all by hosting this site for information as well as selling quality parts and tools that make these repairs possible.
Julie Garbutt - 返信
Hi. I was wondering if I could replace the kindle 3 (keyboard) battery by rigging a 18650? Would that be possible?
Thanks in advance!
Kristof Bodric - 返信
OK, so I'm replying to myself and anyone who's interested. I was too impatient to wait for a reply so I tried it out myself. I opened my Kindle, removed the battery and peeled the paper wrapping off. Then I freed the BMS circuit and kept the plastic frame while snipping off the terminals of my old battery. I soldered 2 wires to the B+ and B- pads on the BMS circuit and soldered their other ends to a 18650 battery holder. I then screwed the frame back in and inserted a generic 18650 battery into the holder, at which point my kindle told me to charge it up. After a few minutes, the device awoke and I was able to read. There. It's a bit ghetto, but with a little work you can attach the battery holder to the back of the kindle and drill a small hole in the back of the case for the cable. Makes battery replacement a breeze and gives your old Kindle a new lease of life as well as a cyberpunk look :)
Kristof Bodric -
I purchased the battery for my Kindle (Gen3) from IFIXIT, and the customer service, shipping and instructions were excellent. I'd recommend that you give them a try - you'll be back. I also like what they offer, which is a way to keep durable products alive, and not having to "rebuy" a perfectly repairable item that you already like. Thanks guys!
hatkins - 返信
I have an old Kindle 3, it was "working" with the original battery but would need to be recharged within a day. I attempted replacement with this kit but it stays on the "Empty Battery" screen. I had charged it overnight and measured 4v on the battery. I swapped the original back in and the kindle booted normally. It seems like it is not seeing the new battery. What can I do to get it going besides the 15/30/40 "hold the power button" reset?
Chris - 返信
My Kindle 3 is up and running again! Thank you!
I definitely second the comment that it seems to make more sense to start prying the back off in the bottom right corner, instead of right around that delicate ribbon cable. I used an opening pick to get it started, and then used the pry tool right next to each latch point. Once I got it to the area near the delicate cable, I was able too remove it the rest of the way by hand.
Daniel - 返信
I am about to take my 1st Kindle—to have battery changed. I’m a little old lady yet capable, but easiest to have ‘pro’ do it(so if messed up, I can fuss at him instead of myself! Haha)
Funny that K3 would still be my favorite even owning current Kindles. However, point of this note is Thank You for such excellent instructions!!
KCampbell, Texas
Lucky Old Lady - 返信
Great tutorial. I lost one of the silver washers found beneath the battery connector. Is it ok to still install new battery or do I need to buy another? if so, do you know where I can find one for Kindle 3rd generation? Thank you
Carlos E - 返信
Fixed my old Kindle Keyboard with this guide and a replacement battery I bought off of this site. Did exactly what was outlined, no unexpected things, easy five minute replacement, device loaded like a charm. Perfect beginner guide, thanks!
As a note, my old battery is swollen and is already in a battery center's disposal bin.
Chris T - 返信
コメントを追加
統計データ:
過去 24時間: 31
過去 7 日: 213
過去 30 日: 990
今までの合計 76,121
