メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Tune 510BT LED and Refractor Replacement
必要な工具と部品
    1. JBL Tune 510BT LED and Refractor Replacement, Faceplate: 手順 1、 2の画像 1 JBL Tune 510BT LED and Refractor Replacement, Faceplate: 手順 1、 2の画像 2
      • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
      • Pull the earmuff towards the center of the headphones until it is free.
      FixBotに聞いてみる
      コメントを追加
    2. JBL Tune 510BT LED and Refractor Replacement: 手順 2、 2の画像 1 JBL Tune 510BT LED and Refractor Replacement: 手順 2、 2の画像 2
      • Remove the three 3 mm screws using a JIS #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. JBL Tune 510BT LED and Refractor Replacement: 手順 3、 1の画像 1
      • Carefully remove the faceplate by lifting it firmly.
      • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
      • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
      • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
      FixBotに聞いてみる
      コメントを追加
    1. JBL Tune 510BT LED and Refractor Replacement, LED and Refractor: 手順 4、 3の画像 1 JBL Tune 510BT LED and Refractor Replacement, LED and Refractor: 手順 4、 3の画像 2 JBL Tune 510BT LED and Refractor Replacement, LED and Refractor: 手順 4、 3の画像 3
      • This is where you would find the rubber housing normally.
      • If the rubber housing is dislodged, which is fairly common, simply replace it in its correct orientation to its seating, being sure to place the indicated piece through the hole to the exterior of the headphones.
      FixBotに聞いてみる
      コメントを追加
    2. JBL Tune 510BT LED and Refractor Replacement: 手順 5、 2の画像 1 JBL Tune 510BT LED and Refractor Replacement: 手順 5、 2の画像 2
      • Heat the small spots of solder where the two LED strips are on the circuit board with a soldering iron.
      • The yellow strip is the white LED, and the white strip is the red and blue LED. Make note of their orientation and positions.
      • Solder the new LEDs into position, making sure the contacts are solid.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ryan
メンバー登録日: 01/30/24
648 ポイント
4のガイドは作成済み
チーム
Utah Tech University, Team 1-2, McMurrin Spring 2024 Utah Tech University, Team 1-2, McMurrin Spring 2024人のメンバー
UTAHTECH-MCMURRIN-S24S1G2
2 メンバー
23のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 67
今までの合計 1,674
