メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Instax Mini 90 Photo Flash Capacitor Replacement
必要な工具と部品
    1. Instax Mini 90 Photo Flash Capacitor Replacement, Battery: 手順 1、 2の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement, Battery: 手順 1、 2の画像 2
      • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
      FixBotに聞いてみる
      コメントを追加
    2. Instax Mini 90 Photo Flash Capacitor Replacement: 手順 2、 2の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 2、 2の画像 2
      • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
      • Completely open the gate and remove from camera. Take out the battery and replace the gate.
      FixBotに聞いてみる
      コメントを追加
    1. Instax Mini 90 Photo Flash Capacitor Replacement, Photo Flash Capacitor: 手順 3、 2の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement, Photo Flash Capacitor: 手順 3、 2の画像 2
      • Face the front side of the camera towards you. To locate the left side turn the left side of the camera towards you.
      • Take out the four screws, sized 4.75 mm, with the Phillips #000 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. Instax Mini 90 Photo Flash Capacitor Replacement: 手順 4、 2の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 4、 2の画像 2
      • Looking at the left side, flip the top of the camera towards you to locate the top side of the camera.
      • Take out the screw, sized 9.75 mm, located on the top side, with a Phillips #000 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Instax Mini 90 Photo Flash Capacitor Replacement: 手順 5、 2の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 5、 2の画像 2
      • Looking at the top of the camera, flip the camera 180 degrees to locate the bottom side of the camera.
      • Take out the screw, sized 3.75 mm, located on the bottom side, this time with a Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    4. Instax Mini 90 Photo Flash Capacitor Replacement: 手順 6、 3の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 6、 3の画像 2 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 6、 3の画像 3
      • Remove the anchors that hold the strap to the body of the camera. There is one on top, and one on the bottom.
      • Use the black spudger to pry off the silver casing on the top and the bottom of the camera.
      • Remove the metal piece from which the film is ejected located on the right side of the camera. There is a 4.75 mm screw under the metal piece. Use a Phillips #000 screw driver to remove it.
      FixBotに聞いてみる
      コメントを追加
    5. Instax Mini 90 Photo Flash Capacitor Replacement: 手順 7、 3の画像 1 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 7、 3の画像 2 Instax Mini 90 Photo Flash Capacitor Replacement: 手順 7、 3の画像 3
      • Open up the camera by releasing the latches on the top of the camera. Pry open the top half of the camera to reveal the capacitor. Locate the capacitor on the top left of the camera.
      • Before handling the capacitor, be sure to discharge it. See the Device Safety wiki for more information.
      • Use the black spudger to pry out the capacitor.
      • Desolder the brown and white wires, taking note of which goes where.
      • Solder the brown and white wires onto the new capacitor.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Elliott Tegan-Tawney
メンバー登録日: 02/28/17
690 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G1, Nance Spring 2017 USF Tampa, Team S2-G1, Nance Spring 2017人のメンバー
USFT-NANCE-S17S2G1
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 45
今までの合計 3,706
