メインコンテンツにスキップ
Huawei P8 Battery Replacement
必要な工具と部品
  1. Huawei P8 Battery Replacement, Huawei P8 Battery Replacement: 手順 1、 2の画像 1 Huawei P8 Battery Replacement, Huawei P8 Battery Replacement: 手順 1、 2の画像 2
    • First switch off your phone.
    • Remove the trays for the SD card and the SIM card.
  2. Huawei P8 Battery Replacement: 手順 2、 1の画像 1
    • Remove the two Torx T2 screws located at the bottom next to the device's Micro USB port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shards and get a better grip to open the phone.
    Torx 2 also works :)
    Dennis Meerveld - 返信
    Tried pentalobe drivers but had to get a Torx 2 in the end, possibly some variation across regional models.
    Ben Raphael - 返信
    Pentalobe screws on my p8…
    In the kit,i have only T2…
    joska Horvath - 返信
    T3 works best, T2 doesn’t cling to the screws too well
    Castlevin - 返信
  3. Huawei P8 Battery Replacement: 手順 3、 2の画像 1 Huawei P8 Battery Replacement: 手順 3、 2の画像 2
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
  4. Huawei P8 Battery Replacement: 手順 4、 1の画像 1
    • Remove the two Phillips #00 screws that secure the front camera and display/battery connector brackets
  5. Huawei P8 Battery Replacement: 手順 5、 3の画像 1 Huawei P8 Battery Replacement: 手順 5、 3の画像 2 Huawei P8 Battery Replacement: 手順 5、 3の画像 3
    • Use a tweezer to remove the bracket covering the display and the battery flex connector.
    • Unplug the battery flex connector with a Spudger.
    • Remove the bracket covering the flex connector of the front camera.
  6. Huawei P8 Battery Replacement: 手順 6、 3の画像 1 Huawei P8 Battery Replacement: 手順 6、 3の画像 2 Huawei P8 Battery Replacement: 手順 6、 3の画像 3
    • Unplug the headphone jack and the front camera flex connectors.
    • Remove the front camera.
  7. Huawei P8 Battery Replacement: 手順 7、 2の画像 1 Huawei P8 Battery Replacement: 手順 7、 2の画像 2
    • Use a spudger to disconnect the power/volume cable and fold it out of the way.
    • Remove the liquid contact indicator.
  8. Huawei P8 Battery Replacement: 手順 8、 1の画像 1
    • Remove the five Phillips #00 screws that hold down the motherboard of your Huawei P8.
  9. Huawei P8 Battery Replacement: 手順 9、 2の画像 1 Huawei P8 Battery Replacement: 手順 9、 2の画像 2
    • Unplug the vibration motor flex connector.
    • Disconnect the antenna cable.
  10. Huawei P8 Battery Replacement: 手順 10、 3の画像 1 Huawei P8 Battery Replacement: 手順 10、 3の画像 2 Huawei P8 Battery Replacement: 手順 10、 3の画像 3
    • Unplug the display flex connector from the main board with a Spudger.
    • Disconnect and remove the antenna cable with a tweezer.
  11. Huawei P8 Battery Replacement: 手順 11、 1の画像 1
    • Remove the motherboard from the phone.
  12. Huawei P8 Battery Replacement: 手順 12、 2の画像 1 Huawei P8 Battery Replacement: 手順 12、 2の画像 2
    • Carefully peel up the flex cable of your loudspeaker.
    • If the cable is difficult to peel, heat the loudspeaker assembly with an iOpener or a heat gun.
    • Lift up the loudspeaker assembly with a spudger and remove it.
  13. Huawei P8 Battery Replacement: 手順 13、 2の画像 1 Huawei P8 Battery Replacement: 手順 13、 2の画像 2
    • Free the end of the first adhesive pull tab to get a good grip on it.
    • Pull the adhesive tab in a slow constant movement to free the battery.
  14. Huawei P8 Battery Replacement: 手順 14、 2の画像 1 Huawei P8 Battery Replacement: 手順 14、 2の画像 2
    • Free the end of the second adhesive pull tab.
    • Pull the adhesive tab in a slow constant movement.
    • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
  15. Huawei P8 Battery Replacement: 手順 15、 2の画像 1 Huawei P8 Battery Replacement: 手順 15、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
終わりに
18 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
203,329 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
9 件のコメント
Really helpful guide. Only hiccup was that on my handset the screws holding the casing together (Step 2) were Torx 2 rather than pentalobe, possibly a regional variation. I opted not to remove the loudspeaker (Step 10) as the ribbon cable was firmly stuck down and I worried it would break. This meant I could only cleanly remove the adhesive pad in line with the charging port. I was able to prise out the battery using spudger and screwdriver to scrape the other pad from the phone body. All now reassembled and working properly!
Ben Raphael - 返信
Overall a very helpful guide . I also had torx screws in mine . The torx screws are tiny , so make sure you have the right screwdriver before starting . We didn’t bother removing the loudspeader assembly either (Step 10) . You can just prise up the ribbon cable (carefully) . Add heat if necessary . Now to the biggest problem . Removing the old battery from the phone . What a nightmare ! It’s really stuck down .We took our time using a hairdryer (no heat gun) , and a flat head screwdriver , and went from one end to the other prising it off gently . It still took about 20 minutes . Saying that . Don’t rush it , as it’s the final stage . Also . If you do use a flat head screwdriver then don’t twist it , as you might damage the casing . Just slide it underneath it applying heat . Total time to remove the old battery was 90 minutes , but about 50 of those were spent just getting the first 2 screws out . 20 minutes to put the new battery in and reassemble . Make sure all flex connectors are properly reseated .
Paul - 返信
My P8 battery has completely died on me. I cannot believe that to replace a battery, we have to now go to these lengths to do it. There must be a mountain of mobile phones, where the only issue with them is a flat battery. Surely, this cannot be allowed to continue. I know why the manufacturers want to make it hard to simply replace a battery, because it sells more mobile phones. But think of all that wasted technology, where a phone may have lasted just over a 24 month contract before the battery is done.
joeninetee - 返信
Many thanks for this tutorial. Together we shall beat them!
joeninetee - 返信
Thank you for a very nice and easy to follow tutorial!
I have now replaced my battery with what should be an original battery for the Huawei Ascend P8, battery nr: HB3447A9EBW. For some reason the width of the new battery is a few millimeters smaller than the old one, meaning that it does not fill out the space completely. Has anyone else experienced the same?
After having assembled the phone again I experience some weird issues with the battery level dropping from 50%, 60%, 70% or even 100% in an instant. I have tried calibrating the battery by, letting it die completely, recharge it to 100% let it drain completely again and recharge. I have tried different battery calibration apps and a factory reset - nothing helps.
I contacted the company I bought the battery from and got a replacement - still same issue.
Unfortunately i damaged the original battery when taking it out, so i cant use that as a reference.
Any suggestions would be most appreciated!
Kris - 返信
Most likely you’ve got a fake battery… :( A telling thing can be if the serial does not match the one you can read from the QR code beside it. Only solution would be to get a genuine one. I can feel your pain.
Bence Szalai -
I have the same issue… I open the back cover and unplug the battery flex connector and then reconnect it again… it is OK for some time but when flex connector is loose again… I grtget the same problem… InIn my case… The battery bracket holding the plug tight is lost and hence connection losen after some time… I smam thing to cut a bracket from a Pepsi Cane…
stahseenjaved -
Great tutorial. Unfortunately the glue stripes were too sticky. Don’t know what Huawei intends to do with such strong stripes. After 30 minutes I could remove them step by step.
Samuel - 返信
after replacing battery phone doesnt switch on only if charger pluged in does it show the hauwie logo then restart same thing again
Dale Olivier - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 66
今までの合計 39,181
