メインコンテンツにスキップ
Huawei P20 Daughterboard Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Huawei P20 Daughterboard Replacement, Rear Glass: 手順 1、 1の画像 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P20 Daughterboard Replacement: 手順 2、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 2、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 2、 3の画像 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P20 Daughterboard Replacement: 手順 3、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 3、 2の画像 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P20 Daughterboard Replacement: 手順 4、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 4、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 4、 3の画像 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P20 Daughterboard Replacement: 手順 5、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 5、 2の画像 2
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P20 Daughterboard Replacement: 手順 6、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 6、 2の画像 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P20 Daughterboard Replacement: 手順 7、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 7、 2の画像 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Huawei P20 Daughterboard Replacement, Motherboard Cover with NFC: 手順 8、 2の画像 1 Huawei P20 Daughterboard Replacement, Motherboard Cover with NFC: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to peel the black tape next to the rear camera off the motherboard cover.
  9. Huawei P20 Daughterboard Replacement: 手順 9、 1の画像 1
    • Remove the eight Phillips #00 screws (3.1 mm length).
  10. Huawei P20 Daughterboard Replacement: 手順 10、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 10、 2の画像 2
    • Use a pair of tweezers to peel the black foil at the bottom end of the phone off the loudspeaker.
  11. Huawei P20 Daughterboard Replacement: 手順 11、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 11、 2の画像 2
    • Slide an opening pick under the right side of the motherboard cover.
    • Rotate the opening pick slightly to pry up the motherboard cover.
  12. Huawei P20 Daughterboard Replacement: 手順 12、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 12、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 12、 3の画像 3
    • Remove the motherboard cover with NFC.
  13. Huawei P20 Daughterboard Replacement, Battery Disconnect: 手順 13、 2の画像 1 Huawei P20 Daughterboard Replacement, Battery Disconnect: 手順 13、 2の画像 2
    • Use a spudger to pry up and disconnect the battery connector.
  14. Huawei P20 Daughterboard Replacement, Daughterboard Cover: 手順 14、 1の画像 1
    • Remove the three Phillips #00 screws (3.2 mm length).
  15. Huawei P20 Daughterboard Replacement: 手順 15、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 15、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 15、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to remove the daughterboard cover.
  16. Huawei P20 Daughterboard Replacement, Charging Board with Main Flex: 手順 16、 1の画像 1
    • Remove the two Phillips #00 screws (3.2 mm length).
  17. Huawei P20 Daughterboard Replacement: 手順 17、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 17、 2の画像 2
    • Use a spudger to pry up and disconnect the main daughterboard connector from the daughterboard.
  18. Huawei P20 Daughterboard Replacement: 手順 18、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 18、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 18、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to pry up and disconnect the connector of the white coax cable from the motherboard.
    • Unroute the white coax cable from the metal clips on the daughterboard and fold it to the side.
  19. Huawei P20 Daughterboard Replacement: 手順 19、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 19、 2の画像 2
    • Use a spudger to disconnect the main flex cable connector from the motherboard.
  20. Huawei P20 Daughterboard Replacement: 手順 20、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 20、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 20、 3の画像 3
    • Remove the charging port and main flex cable by lifting it upwards and then pulling it in the direction of the motherboard.
  21. Huawei P20 Daughterboard Replacement, Battery: 手順 21、 3の画像 1 Huawei P20 Daughterboard Replacement, Battery: 手順 21、 3の画像 2 Huawei P20 Daughterboard Replacement, Battery: 手順 21、 3の画像 3
    • Use a spudger to pry up and disconnect the power and volume button flex connector.
  22. Huawei P20 Daughterboard Replacement: 手順 22、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 22、 2の画像 2
    • Use a spudger to pry up and disconnect the display flex connector and fold the display cable out of your way to remove the battery.
  23. Huawei P20 Daughterboard Replacement: 手順 23、 1の画像 1
    • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  24. Huawei P20 Daughterboard Replacement: 手順 24、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 24、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 24、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Start to slide a plastic card under the bottom right corner of the battery to cut the adhesive.
    • Slide the plastic card along the right side of the battery to further release the adhesive. Gently start to pry up the battery while doing so.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
  25. Huawei P20 Daughterboard Replacement: 手順 25、 3の画像 1 Huawei P20 Daughterboard Replacement: 手順 25、 3の画像 2 Huawei P20 Daughterboard Replacement: 手順 25、 3の画像 3
    • Slide the plastic card under the whole upper part of the battery and cut the adhesive with it.
    • Slide the plastic card down to the bottom end of the battery to cut the remaining adhesive.
    • Use the plastic card to pry up the battery.
  26. Huawei P20 Daughterboard Replacement: 手順 26、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 26、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
  27. Huawei P20 Daughterboard Replacement, Daughterboard: 手順 27、 1の画像 1
    • Remove the two Phillips #00 screws (3.4 mm length).
  28. Huawei P20 Daughterboard Replacement: 手順 28、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 28、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to disconnect the black coax cable and fold it out of your way.
  29. Huawei P20 Daughterboard Replacement: 手順 29、 2の画像 1 Huawei P20 Daughterboard Replacement: 手順 29、 2の画像 2
    • Use a pair of tweezers to remove the daughterboard.
終わりに
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
230,403 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,547のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 32
