メインコンテンツにスキップ
How to Install a Plastic Snap With a Handheld Tool
必要な工具と部品
  1. How to Install a Plastic Snap With a Handheld Tool, Snap information: 手順 1、 2の画像 1 How to Install a Plastic Snap With a Handheld Tool, Snap information: 手順 1、 2の画像 2
    • A full set of plastic snaps consists of four parts:
    • Two caps
    • One stud
    • One socket
    • When the snap is installed, the socket and stud will lock together, while a cap holds each of them in place from the other side of the fabric.
  2. How to Install a Plastic Snap With a Handheld Tool, Pierce the fabric: 手順 2、 2の画像 1 How to Install a Plastic Snap With a Handheld Tool, Pierce the fabric: 手順 2、 2の画像 2
    • Push the point of an awl through the fabric to pierce a hole for the snap.
    • It's better to measure twice, pierce once! Piercing the fabric multiple times within a small area will weaken the fabric.
  3. How to Install a Plastic Snap With a Handheld Tool, Install the snap: 手順 3、 3の画像 1 How to Install a Plastic Snap With a Handheld Tool, Install the snap: 手順 3、 3の画像 2 How to Install a Plastic Snap With a Handheld Tool, Install the snap: 手順 3、 3の画像 3
    • Use your fingers to squeeze a cap pin through the fabric hole.
  4. How to Install a Plastic Snap With a Handheld Tool: 手順 4、 3の画像 1 How to Install a Plastic Snap With a Handheld Tool: 手順 4、 3の画像 2 How to Install a Plastic Snap With a Handheld Tool: 手順 4、 3の画像 3
    • Place either a stud or a socket on top of the pin.
    • If you can't see the pin after placing the stud or socket, the fabric is too thick for the snap. You'll need a cap with a longer pin.
  5. How to Install a Plastic Snap With a Handheld Tool: 手順 5、 2の画像 1 How to Install a Plastic Snap With a Handheld Tool: 手順 5、 2の画像 2
    • Make sure the snap is facing the correct side for the clothing item.
    • Center the snap components in the fastener tool. The cap should sit fully in the black die cup.
  6. How to Install a Plastic Snap With a Handheld Tool: 手順 6、 3の画像 1 How to Install a Plastic Snap With a Handheld Tool: 手順 6、 3の画像 2 How to Install a Plastic Snap With a Handheld Tool: 手順 6、 3の画像 3
    • Firmly squeeze the fastener tool handles. The white rubber head should bulge slightly from the force.
    • Release the handles and remove the tool from the snap.
  7. How to Install a Plastic Snap With a Handheld Tool, Check the new snap: 手順 7、 2の画像 1 How to Install a Plastic Snap With a Handheld Tool, Check the new snap: 手順 7、 2の画像 2
    • Visually inspect the snap. The center pin should be evenly flattened.
    • Pull on the snap. The snap shouldn't feel loose.
    • If the pin isn't evenly flattened or the snap feels loose, use the fastener tool to compress the snap again. If that doesn't fix it, remove the snap and start again.
  8. How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: 手順 8、 3の画像 1 How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: 手順 8、 3の画像 2 How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: 手順 8、 3の画像 3
    • Repeat the procedure to install the other half of the snap set.
終わりに
For more clothing repair guides, click here.
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
310,105 ポイント
701のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,638のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 74
過去 30 日: 259
今までの合計 1,334
