はじめに
If the headlights of your Hover-1 Rally (model H1-RALY) scooter do not turn on or are dim, use this guide to replace them. Damaged wires or a burnt out bulb may be the cause of the faulty headlights. These components are easy to fix.
Step 3 requires you to remove two wires from the headlight. This will require you to desolder the wires in order to detach them.
Make sure to power off the scooter before beginning this guide.
必要な工具と部品
ある他の人がこのガイドを完成しました。
