はじめに
This guide will walk you through how to replace a faulty or wobbly kickstand on a Hover-1 Eagle scooter. You should replace your kickstand if your kickstand is defective, wobbly, or not the proper length. To determine if you need to replace your kickstand, refer to our Troubleshooting Guide.
必要な工具と部品
Remove the two 6mm axle screws using a hex bit 4.0.
Remove the kickstand from the scooter.
2 の人々がこのガイドを完成させました。
