はじめに
This page will guide you through the replacement of the quick burst button on your Hamilton Beach Classic Stand Mixer 64650. This guide is helpful if you are experiencing any problems with using the quick burst button on your device. It is possible that either the button assembly is broken or the spring keeping the button in place is broken, so you'll have to open it to check it out!
必要な工具と部品
Remove the seven 1.3 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
ある他の人がこのガイドを完成しました。
