メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Excalibur Screen Replacement
必要な工具と部品
  1. HTC Excalibur Screen Replacement, Motherboard: 手順 1、 1の画像 1
    • Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
    • Pry loose the metal cover near the camera lens.
    FixBotに聞いてみる
    コメントを追加
  2. HTC Excalibur Screen Replacement: 手順 2、 1の画像 1
    • Remove the battery cover.
    • Gripping the battery by the bottom, lift and remove it from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. HTC Excalibur Screen Replacement: 手順 3、 3の画像 1 HTC Excalibur Screen Replacement: 手順 3、 3の画像 2 HTC Excalibur Screen Replacement: 手順 3、 3の画像 3
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
    • After loosening the case, remove it.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
    FixBotに聞いてみる
    コメントを追加
  4. HTC Excalibur Screen Replacement: 手順 4、 2の画像 1 HTC Excalibur Screen Replacement: 手順 4、 2の画像 2
    • Remove the one remaining screw in the logic board.
    • Unclip the wire that connects the back of the case to the logic board.
    FixBotに聞いてみる
    コメントを追加
  5. HTC Excalibur Screen Replacement: 手順 5、 3の画像 1 HTC Excalibur Screen Replacement: 手順 5、 3の画像 2 HTC Excalibur Screen Replacement: 手順 5、 3の画像 3
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Do this at an angle, lifting the side to the right of the SIM card instructions.
    • One of the strips is attached to the front of the case, and goes through the logic board. Be careful not to break this piece.
    FixBotに聞いてみる
    コメントを追加
  6. HTC Excalibur Screen Replacement, Screen: 手順 6、 1の画像 1
    • Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
    FixBotに聞いてみる
    コメントを追加
  7. HTC Excalibur Screen Replacement: 手順 7、 1の画像 1
    • Grab the screen by the bottom edge, and lift it out at an angle.
    • Replace the screen, and reassemble the phone.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Ian Mitchell
メンバー登録日: 04/19/11
142 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-27, Garner Spring 2011 Cal Poly, Team 25-27, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G27
4 メンバー
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 26
今までの合計 2,145
