メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Stream 7 Screen Replacement
必要な工具と部品
    1. HP Stream 7  Screen Replacement, Battery: 手順 1、 2の画像 1 HP Stream 7  Screen Replacement, Battery: 手順 1、 2の画像 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      FixBotに聞いてみる
      コメントを追加
    2. HP Stream 7  Screen Replacement: 手順 2、 2の画像 1 HP Stream 7  Screen Replacement: 手順 2、 2の画像 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      FixBotに聞いてみる
      コメントを追加
    3. HP Stream 7  Screen Replacement: 手順 3、 2の画像 1 HP Stream 7  Screen Replacement: 手順 3、 2の画像 2
      この手順で使用する道具:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      FixBotに聞いてみる
      コメントを追加
    1. HP Stream 7  Screen Replacement, Motherboard Replacement: 手順 4、 1の画像 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      FixBotに聞いてみる
      コメントを追加
    2. HP Stream 7  Screen Replacement: 手順 5、 2の画像 1 HP Stream 7  Screen Replacement: 手順 5、 2の画像 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    3. HP Stream 7  Screen Replacement: 手順 6、 2の画像 1 HP Stream 7  Screen Replacement: 手順 6、 2の画像 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      FixBotに聞いてみる
      コメントを追加
    1. HP Stream 7  Screen Replacement, Screen Replacement: 手順 7、 1の画像 1
      • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
      FixBotに聞いてみる
      コメントを追加
    2. HP Stream 7  Screen Replacement: 手順 8、 1の画像 1
      • Using your spudger, pry the display panel off the front.
      FixBotに聞いてみる
      コメントを追加
    3. HP Stream 7  Screen Replacement: 手順 9、 1の画像 1
      • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Justin Schnorf
メンバー登録日: 10/03/16
252 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 18-5, Forte Fall 2016 Cal Poly, Team 18-5, Forte Fall 2016人のメンバー
CPSU-FORTE-F16S18G5
4 メンバー
9のガイドは作成済み
6件のガイドコメント
where can i buy new screen????
eibrims - 返信 共有
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - 返信 共有
Where can i buy a new screen for the stream 7 please??
migueajr - 返信 共有
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - 返信 共有
We're I can buy the replacement screen?
Raymond Borrero - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 36
今までの合計 4,746
