はじめに
Before beginning this hard drive replacement, make sure your laptop is unplugged and powered off. Then follow the steps for removing the back cover and battery from the HP ProBook 640 G2 Battery Replacement Guide before moving on to the next step.
必要な工具と部品
Flip the laptop so the bottom is facing up.
Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
Use a Torx T9 screwdriver to remove the single 6 mm screw.
Loosen the four JIS J1 captive screws on the hard drive tray.
Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
