メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP ProBook 640 Fan Replacement
必要な工具と部品
    1. HP ProBook 640 Fan Replacement, Battery: 手順 1、 1の画像 1
      • Turn the laptop upside down to show the battery lock slider.
      • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
      FixBotに聞いてみる
      コメントを追加
    2. HP ProBook 640 Fan Replacement: 手順 2、 1の画像 1
      • Slide the battery slider all the way to the left, towards the battery symbol.
      • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
      FixBotに聞いてみる
      コメントを追加
    3. HP ProBook 640 Fan Replacement: 手順 3、 1の画像 1
      • Remove the battery by sliding it away from the laptop while holding the battery locker.
      • The battery should slide out with ease.
      FixBotに聞いてみる
      コメントを追加
    1. HP ProBook 640 Fan Replacement, Back Panel: 手順 4、 2の画像 1 HP ProBook 640 Fan Replacement, Back Panel: 手順 4、 2の画像 2
      • Slide down and pull up on the cover to remove it.
      FixBotに聞いてみる
      コメントを追加
    1. HP ProBook 640 Fan Replacement, Midframe: 手順 5、 3の画像 1 HP ProBook 640 Fan Replacement, Midframe: 手順 5、 3の画像 2 HP ProBook 640 Fan Replacement, Midframe: 手順 5、 3の画像 3
      • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
      • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
      • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
      • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
      FixBotに聞いてみる
      コメントを追加
    2. HP ProBook 640 Fan Replacement: 手順 6、 2の画像 1 HP ProBook 640 Fan Replacement: 手順 6、 2の画像 2
      • Remove the disk drive by gently pulling it out.
      • Remove the two 3 mm screws using a Phillips #1 screwdriver.
      • Only one screw is visible in the photo the second screw is located directly above it.
      FixBotに聞いてみる
      コメントを追加
    3. HP ProBook 640 Fan Replacement: 手順 7、 2の画像 1 HP ProBook 640 Fan Replacement: 手順 7、 2の画像 2
      • Gently pull up on the midframe, gripping it from the inside.
      • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
      FixBotに聞いてみる
      コメントを追加
    1. HP ProBook 640 Fan Replacement, Fan: 手順 8、 2の画像 1 HP ProBook 640 Fan Replacement, Fan: 手順 8、 2の画像 2
      • Loosen the two captive screws in the fan using a Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. HP ProBook 640 Fan Replacement: 手順 9、 2の画像 1 HP ProBook 640 Fan Replacement: 手順 9、 2の画像 2
      • Carefully lift the fan and disconnect its cable from the motherboard.
      • Remove the fan from the laptop.
      • Avoid touching motherboard components directly to prevent static damage.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Taiyaba Asif
メンバー登録日: 11/04/25
214 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 UMass Dartmouth, Team 4-2, Biswokarma Fall 2025人のメンバー
UMASSD-BISWOKARMA-F25S4G2
5 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 264
