はじめに
Does your HP ProBook 440 g6's fans produce loud noises? Does your device overheat despite of cleaning it? In this guide, we'll walk you through the steps to replace your HP ProBook 440 g6 fan. The fan is a key part of a laptop as it provides active cooling to the reset of the device parts. This allows the parts to stay at a desired temperature so that they may each perform their function as intended.
Common Symptoms you may face due to a faulty fan include:
- Loud grinding fan noise
- Persistent overheating despite cleaning
- Repeated hard drive clicking with file error
- System suddenly freezes or shuts down
Here, we'll guide you step-by-step to ensure a safe and smooth replacement of your device's fan. Before we continue onto the replacement, make sure to put your device in Battery Safe mode, completely shut down your device, and unplug it from your charger.
必要な工具と部品
Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
