メインコンテンツにスキップ
HP Omen 15-ax243dx Battery Replacement
必要な工具と部品
  1. HP Omen 15-ax243dx Battery Replacement, Battery: 手順 1、 2の画像 1 HP Omen 15-ax243dx Battery Replacement, Battery: 手順 1、 2の画像 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Battery Replacement: 手順 2、 2の画像 1 HP Omen 15-ax243dx Battery Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Battery Replacement: 手順 3、 2の画像 1 HP Omen 15-ax243dx Battery Replacement: 手順 3、 2の画像 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Battery Replacement: 手順 4、 2の画像 1 HP Omen 15-ax243dx Battery Replacement: 手順 4、 2の画像 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
vangnam
メンバー登録日: 10/19/17
594 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G7
3 メンバー
7のガイドは作成済み
8 件のコメント
Hello,
I replaced the battery but it is not charging. I know it’s an easy repair, but I checked the pins but not sure where the problem is.
Any ideas?
Thank you
Kiran M - 返信
Hi Kiran,
Does the laptop show any indication that it detects the battery?
Arthur Shi -
I’ve replaced the battery with one I bought from here, and I believe it may be faulty? My laptop is not detecting a battery, I opened it back up and followed the guide again to make sure I did everything right, and made sure the battery cord was inserting securely, still nothing.
AwSnoopy - 返信
Hello! Please contact our customer support and we will get the issue resolved!
Arthur Shi -
We took the battery out of your laptop then put it back in because it wouldnt turn on, it turns on now but the left usb ports are not getting powered, is there any way to make sure that they are powered when we get our replacement battery in the laptop?
Drake Mitchell - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 35
過去 30 日: 183
今までの合計 24,121
