メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Chromebook 11 G6 EE Webcam Camera Module Replacement
必要な工具と部品
  1. HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Keyboard: 手順 1、 3の画像 1 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Keyboard: 手順 1、 3の画像 2 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Keyboard: 手順 1、 3の画像 3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
    FixBotに聞いてみる
    コメントを追加
  2. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 2、 3の画像 1 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 2、 3の画像 2 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 2、 3の画像 3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
    FixBotに聞いてみる
    コメントを追加
  3. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 3、 2の画像 1 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 3、 2の画像 2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
    FixBotに聞いてみる
    コメントを追加
  4. HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Webcam Camera Module: 手順 4、 3の画像 1 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Webcam Camera Module: 手順 4、 3の画像 2 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Webcam Camera Module: 手順 4、 3の画像 3
    • Use the opening pick around the edges of the screen bezel carefully to remove.
    • Remove screen bezel.
    FixBotに聞いてみる
    コメントを追加
  5. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 5、 3の画像 1 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 5、 3の画像 2 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 5、 3の画像 3
    • Peel back the tape that secures the webcam to the left display panel hinge.
    • Gently slide out the webcam connector.
    FixBotに聞いてみる
    コメントを追加
  6. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 6、 2の画像 1 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 手順 6、 2の画像 2
    • Place the iFixit opening tool under the webcam module.
    • This is will probably bend the metal due to the strong adhesive in place.
    • Using the iFixit tool work the tool around the top edge of the webcam module to loosen the module.
    • Use your fingers to lift the webcam module out of its setting.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Israel Barnes
メンバー登録日: 09/06/23
99 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 489
